2011 FXDWG/I
Old Jul 16, 2025 | 07:55 AM
Azdynaglide's Avatar
Azdynaglide
Stage IV
Default 2011 FXDWG/I
2011 dyna blown egn fuse won't start .Bike died would not run.back home the egn fuse was blown .Charged the battery and engine cranks over very good no starting.yes fuse was replaced plenty of fuel .doing diag code check brb with codes .appreciate any info will check diagnostics for fault codes .help
should I replace coil and or crank position sensor. lost did diag. but won't start to see if codes are in history or present . hope for a idea to get the bike to start . turns over good not starting . Thank you any idea or check list to see what's not working .
Old Jul 16, 2025 | 02:01 PM
John CC's Avatar
John CC
So it's missing either fuel or spark. Pull a plug out and see. Is it wet with gas? (We used to put a lit match to the plug hole...) Lay it against the head and crank. Does it spark?
Old Jul 16, 2025 | 05:56 PM
Coverdog's Avatar
Coverdog
Old Jul 16, 2025 | 06:57 PM
Roberto88's Avatar
Roberto88
Check for shorts in ignition wiring, especially near the steering head. Unplug the coil and crank sensor one at a time - if fuse stops blowing, you've found the bad part. No spark? Test coil and crank sensor. Verify grounds are clean and tight. Start with these checks first.
Old Sep 20, 2025 | 06:02 PM
Azdynaglide
Stage IV
Default well the fuel pump comes on.
=John CC;22070422]So it's missing either fuel or spark. Pull a plug out and see. Is it wet with gas? (We used to put a lit match to the plug hole...) Lay it against the head and crank. Does it spark?
Well I can hear fuke pump cone on . should I leave the plugs in. And get a spark plug and pull the back plug wire off and plug it into the spark plug lay it on the head and check for spark . Like that . just don't want to replace the coil or crank position sencer if they are good . forgive the time it takes me to catch back up. hard situation at present . State has taken my house for property taxes . trying to recover and the process of getting it back. I am homeless and difficulty in getting back . but need to get some therapy only my Dyna can provide. Sincerely an avid rider . please forgive any delays . Peace
Azdynaglide appreciate very much the help always
Old Sep 21, 2025 | 11:23 AM
nevil's Avatar
nevil
Grounding the spark plug on the cylinder won't work. The ECM needs to detect compression or it won't call for spark.
An inline spark wire detector is the way to go.
You should also get the battery charged up and get it load tested. Don't think of replacing parts unless you have a healthy battery, and have tested any other components to determine if they are faulty.
Old Sep 21, 2025 | 11:45 AM
upflying's Avatar
upflying
2011 dyna blown egn fuse won't start . .
What caused the ignition fuse to blow?
HD publishes the wiring diagram .
99949-11_en - 2011 Wiring Diagrams | Harley-Davidson SIP
skyrhon
May 13, 2022 05:48 PM
Big_Dave88
Jan 19, 2021 05:43 AM
alvinator
Jul 6, 2014 11:21 AM
tcataldo
Mar 20, 2014 09:29 AM
jtip1277
Sep 3, 2011 07:37 AM
