2006 street bob torque spec questions
Old Sep 5, 2025 | 08:36 AM
CenCalJack's Avatar
CenCalJack
6th Gear
Default 2006 street bob torque spec questions
I'm looking for the torque specs for the rear pulley bolts to the hub and the axle bolt.
Thanks in advance for any help.
Old Sep 5, 2025 | 10:05 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sorry, I don`t have a manual for that bike because I don`t own one, so I can`t tell you the torque or proper procedure.
This is where you get into trouble because you are not following a service manual, the forums have numerous posts about rear belt sprockets coming loose and ruining the wheel, mostly because the people doing the job did not follow the proper process.
It`s time to tell your grandson to buy a genuine Harley Davidson Service Manual.
Old Sep 5, 2025 | 08:39 PM
Roberto88's Avatar
Roberto88
For the rear pulley bolts, torque them to 80-85 ft-lbs.
For the rear axle nut, torque it to 120-125 ft-lbs.
Always use a new cotter pin on the axle nut and make sure the bolts have thread locker.
Old Sep 5, 2025 | 09:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Another incorrect generic AI answer from Roberto88.
OP: Use new bolts on the rear sprocket.
The axle takes an "E" clip, not a cotter pin.
Old Sep 6, 2025 | 12:34 AM
south69's Avatar
south69
Per 2007 Street Bob Service Manual
Rear axle nut 92-98 ft-lbs 124.7-132.9 Nm page 2-15
Belt sprocket screws 55-65 ft-lbs 74.6-88.1 Nm page 2-13
For rear sprocket bolts always use NEW hardware and always thread chase the holes make sure threads are CLEAN.
IMO I use red loctite and go over the stated torque in the service manual and go to 75 ft-lbs...
Old Sep 6, 2025 | 06:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The OP is getting a good amount of bad advice in this thread.
@CenCalJack : Don`t over torque the sprocket retaining bolts.
Old Sep 6, 2025 | 06:36 AM
south69's Avatar
south69
def not bad advice but you are entitled to your own opinion sir.
Rear pulley bolts were known to back out. decided to bust out the more modern 2015 street bob service manual and it states Rear sprocket screws-final torque 67-73 ft-lbs 90.9-99.0 Nm 2.5 REAR WHEEL, Assembly
Do what you will but at 75 ft-lbs you wont have a problem if you have solid grade 8 hardware and a properly calibrated torque wrench.
Old Sep 6, 2025 | 08:36 AM
hattitude's Avatar
hattitude
Your bike, your call.....
FWIW...
The 2007 sprocket bolts #3109, come with lock patch on the threads. The torque spec in the manual takes that lock patch into account.
By adding red loctiite on your own, you are adding a lubricant (wet locktite) to the threads, which usually requires a 20% decrease to a dry torque spec.
You choose to increase the factory torque spec after adding a lubricant to the threads. You are most likely over torquing the sprocket bolts. That can sometimes be worse than under torquing.
Old Sep 6, 2025 | 08:54 AM
CenCalJack's Avatar
CenCalJack
6th Gear
Any suggestions for a PDF manual download?
Old Sep 6, 2025 | 03:41 PM
south69's Avatar
south69
FWIW...
True! I gave the factory torque specs from the manual and also my opinion. OP can do what he wants at the end of the day. I was simply saying what worked/works for me. Installed a few pulleys and sprockets on different wheels be it my own or buddies and have always done red and 75 with no issues. Not saying its right just what i do.
One thing I will say tho regardless what torq you end up using I would suggest using a way to mark the bolt heads against the pulley and check them on your pre ride. Cheers guys!
