Ordering shocks. What length?
Old Feb 6, 2026 | 12:29 PM
Bushop's Avatar
Bushop
Default Ordering shocks. What length?
I am ready to order rear shocks for my 2009 FXDC.
Stock shock length looks to be 12.5".
Going to order Progressive Suspension 412 series with hd springs.
I am 6', 270 lbs., most likely never a passenger, maybe some traveling stuff in the bags, so I figured the hd springs are the best choice for me.
Do you suppose the 13.5" are a good length or should I go for the 14"?
Your 2 cents???
Thanks,
Chris
Old Feb 6, 2026 | 12:37 PM
fskitch's Avatar
fskitch
Heavy duty 13.5.
Get a 1” longer kick stand to go with it otherwise you’ll have too aggressive lean angle when parked.
Old Feb 6, 2026 | 12:38 PM
eighteight's Avatar
eighteight
Jack it up and make sure 14`s don`t pose an exhaust / axle nut interference
Old Feb 6, 2026 | 04:15 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Yup, IIRC even a 13 inch shock has interference with the stock exhaust
Old Feb 7, 2026 | 06:08 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Since you’re not taking a passenger then you might want to go with stock length.
Old Feb 7, 2026 | 09:35 AM
Tommy C's Avatar
Tommy C
A longer shock will give the OP more suspension travel and lean angle and make the bike more fun to ride.
Old Feb 7, 2026 | 09:58 AM
08xl1200r's Avatar
08xl1200r
Maybe...longer shocks don't always have more travel, depends on the manufacturer, something to definitely check before going that route...some like Ohlins provide that info.
I'd thought of doing that on my own Dyna but the stock length works OK, even 2 up...will maybe sometime experiment with the longer Ohlins shocks on my Sportster.
(the weight difference between the bikes is only about 40 lbs., Evo Super Glide vs. rubber mount Sportster)
Old Feb 8, 2026 | 11:23 AM
nevil's Avatar
nevil
You might want to verify the length of your stock shocks. On my 07 Street Bob they were 12".Yours may be different but it can't hurt to check.
Old Feb 14, 2026 | 05:16 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Stock length is what works best unless your going to make the same change in the front...
Dprintz
Apr 15, 2018 07:07 PM
Roadster
2014-2024 Touring Models
17
Sep 8, 2017 09:53 AM
RobV10
Sep 27, 2012 12:11 PM
yorgo
Oct 28, 2009 07:31 AM
SmokinRK
Jul 19, 2007 10:48 AM
