i need a straight answer
Old Sep 18, 2007 | 08:29 PM
cardboard's Avatar
cardboard
Default RE: i need a straight answer
If you want sound and you want performance git you a set of D&D Fat Cat pipes and a Thundermax with auto tune. Then you can tune yer bike easy and when you make changes you don't have to pay the dealer.
Old Sep 19, 2007 | 07:56 AM
cjhumphrey's Avatar
cjhumphrey
it came with the screaming eagle high flow air cleaner, and has screaming eagle pipes on it. my problem is they both suck donkey *****.
I just wanted to go on record as defending the S/E pipes as not totally sucking donkey *****. The upper 4 inches of the headerflange end are perfect for cutting off and using to make custom pipes...
Old Sep 19, 2007 | 08:23 AM
Trotter's Avatar
Trotter
Greg you have a He(( of a exhaust leak on you front pipe looking at you sig pic... ?
Old Sep 19, 2007 | 09:08 AM
Stanger's Avatar
Stanger
Put everything on, ride and see what it does. If it seems ok, then you may be ok. The only thing to caution you on is that if you are running to lean, you could cause some real damage to the motor, so it is kind of up to you. I did something of this to mine, and before I even started it I put on a PCIII and have not looked back. I wish you luck in what ever direction you choose to go.
Old Sep 19, 2007 | 09:19 AM
remipmc's Avatar
remipmc
thanks for all the input, i think im going to put the pipes on and see how they sound/feel first. then if need be ill probably go with the PC3 usb.
Old Sep 19, 2007 | 08:11 PM
fj4069's Avatar
fj4069
ORIGINAL: remipmc
have the pcIII off my 06 if you want to buy it. give you a good deal. guy dynoing my bike on friday is gonna flash my factory chip so i will be taking it off on friday morning..
Old Sep 19, 2007 | 09:16 PM
remipmc's Avatar
remipmc
cool, holler at me with the details!
Old Sep 19, 2007 | 09:37 PM
darkdyna06's Avatar
darkdyna06
You just got a PM, I may have the answer for you sitting on top of my tool box.
Fuzzman
Apr 17, 2014 10:43 AM
Hellcat1
Jun 20, 2010 07:34 AM
usaztec66
Feb 21, 2009 11:55 PM
Frog74
Jul 10, 2008 06:43 AM
Leester
May 28, 2008 11:18 PM
