check engine light
Old Oct 8, 2007 | 04:50 PM
snooper0069's Avatar
snooper0069
Default check engine light
[&o] I just put on a Vance and Hines Fuel Pak on my 07 Dyna and it runs great.But now the check engine light comes on and goes off constantly. Like I said the bike couldnt run any better than it is now so Im not to worried about it.Iv read were piggy-backing has been known to create this type of problem.
Old Oct 8, 2007 | 05:43 PM
matkiwi's Avatar
matkiwi
Default RE: check engine light
check the connectors on the fuelpak ... might be a bit of dust/water ingress ... mine did that before i filled them with vaseline due to water completely screwing the ignition ... runs fine now.
Old Oct 8, 2007 | 06:03 PM
up in minot's Avatar
up in minot
Did you follow the directions to the tee? They state to keep both the ignition off AND the kill switch off, until the instructions say to turn them on. It states that if you don't follow those steps, the light will come on. Just a thought... If that's the case, it would be an easy fix.
Old Oct 8, 2007 | 07:49 PM
snooper0069
Yep I followed all the instructions to a "t".Seems like if it was a bad connection it would run bad tho, and it runs just fine.
XMA
May 27, 2013 07:54 PM
myrtle2008
Jan 16, 2013 08:01 PM
WNMORE
Jul 17, 2010 11:39 PM
Jock
Apr 27, 2008 01:20 AM
03 Softail
Mar 12, 2006 01:14 AM
