Check Engine Light
Old Mar 11, 2006 | 06:12 PM
03 Softail's Avatar
03 Softail
Default Check Engine Light
Whats the problem: My check engine light comes on when I turn my ignition switch on, it stays
on for approx. 4 sec. goes off then I start the bike, after the bike has run for 5 to 10 sec.
the check engine light will come back on and stay on for approx. 5 to 10 sec. then go off
and not come back on while I'm riding. The bike runs fine.
I've taken it back to the dealer 3 or 4 time now and they have reset the computor to delete
this code. They tell me it's a false code. I can go for quite a while without this problem once
they reset my computor, but in time the problem will return.
Has any one else run across this type of problem, what would cause the check engine light to
come on, it does not flash, like you would be getting a trouble code. Bike is fuel injected, 03 softail standard, Vance and Hines big radius pipes, dealer download, Kuryakyn
Hypercharger. Thanks for any information on this problem.
Dan
Old Mar 11, 2006 | 06:24 PM
UltraScoot's Avatar
UltraScoot
Default RE: Check Engine Light
Check out this link in the DIY form https://www.hdforums.com/m_322770/tm.htm it might help you.
Old Mar 11, 2006 | 06:31 PM
HDF Tech's Avatar
HDF Tech
This one may help you diagnose the error code, it will then tell you what is causing it and could be even a bad start setting a code too.
https://www.hdforums.com/m_64805/tm.htm
Old Mar 11, 2006 | 06:32 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: 06deluxe_scoot
That proceedure is used if the blinkers flash repeatedely when the ignition is turned on. (TSSM codes)
Old Mar 11, 2006 | 08:12 PM
UltraScoot's Avatar
UltraScoot
ORIGINAL: TCSTD
Opps!! my bad, thanks TCSTD for setting me straight.
Old Mar 11, 2006 | 08:23 PM
HDF Tech's Avatar
HDF Tech
No problem here, I'm glad you checked in the DIY and can help out giving links that will help others. Some of those topics can be a bit confusing until you work with them a bit , then they make sense.
Good Job, keep it up!
Old Mar 12, 2006 | 01:09 AM
fatheadonsoftail's Avatar
fatheadonsoftail
How do you clear the code using this method? My Blinkers do not flash, Just the light comes on after it starts for about 4-5 seconds
Old Mar 12, 2006 | 01:14 AM
HDF Tech's Avatar
HDF Tech
If it is a historic code that is lighting the light, it will clear itself after 50 starts (ignition cycles) of at least 30 seconds run time each.
If it is a current code lightnig it, the dealer has to reset it and the problem has to be fixed first.
Conga
Apr 7, 2018 11:49 AM
saxmanwizard
May 29, 2012 03:49 AM
AdrianVall
Sep 6, 2011 04:44 PM
SE120RG
Jul 20, 2009 08:00 AM
VRodRider
VRSC Models
16
Sep 4, 2007 02:52 PM
