For you new Dyna owners, I have a question about the air cleaner.
As I understand it, the new stock can has solenoid controlled flapper to open the can when the engine needs more air. Controlled by rpm? And there must be some other opening in the can to allow air to enter the rest of the time.
In the past, everybody swapped the air cleaner in an attempt to gain more power (which worked). But it worked by providing a more open can, not by replacing the filter element. If you simply drilled some 3/4-1" holes in the backing plate, it worked just as well as the SE and it was free. Paper elements are actually quite good for airflow. And there are less expensive gauze/oil alternatives to K&N.
Can you use the same tricks on the new ones with the same results?
The holes will increase the intake of air into the filter area, but the stock filter is still the restriction here, refer to your other post on K&N filters for an explination. https://www.hdforums.com/m_198277/mp.../tm.htm#199439
Taller is better, not wider.
Actually it is a combination fo both that gives the increase here.
The referanced post was in regards to a '98 Evo. The filters were almost exactly the same size between stock and SE then. The SE kit for the sporty was the same way. The performance advantage of a K&N filter alone is suspect at best. For the Evo kits, the advantage came from oepning up the can for better air flow, not from replacing thefilter.
And that's why I'm asking about the new engines, because I just didn't know if it's the same now as it was then. Nice to know there's been an improvement, as I thought the SE air cleaner was a rip off in the past. Bigger elements are usually an improvement.
I also read somewhere (here?) that the new SE kit includes a paper element. And that recently a K&N replacement was available. Is that true?
That is very true. HD had a contract with K&N that terminated for whatever reason and they stopped using the K&N filter in the stage kits. The Ness big sucker has the K&N filter in it and works well too.
I believe the flapper is only on international models. My '06 Dyna had the typical EFI air box - no flapper. I pulled it and replaced with the SE. There is a plugged pigtail that hangs behind the box. I assume it's meant to control the international flapper.
The current SE air cleaner kit gives you a new backing plate with a better (?) PCV system, an open can, and a taller paper element. The original cover is still used. For $140. Do you think this is a good value?
Or can you accomplish the same thing by modifying the stock parts?
You can order all the parts that come with kit, minus the filter element and save some money. Use a K&N filter instead. There is a big thread about this and you might want to read it.. if you are comfortable working on your own bike, this is the way to go. If not, have the dealer install the kit. You will need to get the dealer to do a Stage I download for the EFI if you modify the AC. Even better would be to buy a SERT or a DFO. Here is a link to the thread..
