Dyna Rear tire size .. Confusion.
Old Dec 4, 2007 | 12:20 AM
abcd9906's Avatar
abcd9906
Default Dyna Rear tire size .. Confusion.
On the stock rim ... can you run a 190? 200?
For a 200 ..(SAFELY) Softail 6" rim with a 200 and a spacer set and cut one down a little bit so it all lines up?
How big can I go with a stock rim and not risk bead coming off?
Old Dec 4, 2007 | 12:28 AM
trip20's Avatar
trip20
Default RE: Dyna Rear tire size .. Confusion.
I know you can do 180 safely. More than that... I'm not sure.
Old Dec 4, 2007 | 12:34 AM
abcd9906's Avatar
abcd9906
I seen a chart somewhere that showed with each size of rim and for what years certain tires that will fit. Like 4.5" rim 140,160,180
5.5 - 6.0 190 200 210
Etc ... anyone seen something similar??
Old Dec 4, 2007 | 01:14 AM
Big Twi$t's Avatar
Big Twi$t
I would just like to know if I can fit a 200 on my 08 Fat Bob. My past bikes (none which were Harleys) the general rule was you could go up 1 or 2 tire sizes (width) on the stock rim.
Old Dec 4, 2007 | 10:47 AM
Shrug's Avatar
Shrug
I went with a SE 180 on my WG; no mods or wide tire kits needed, despite the stealer's insistance that they were. I read here somewhere you can get a 200 on a 5.5 rim, but the axle spacers and drive belt will have to be changed. A forum search might yield some help. Let us know what you find.
Old Dec 4, 2007 | 12:59 PM
treeextractor's Avatar
treeextractor
You could run a metz190 on the stock wheel, tight fit on bead,but it willnot look/handel right, I know I tried it. Also remember different tire manufacture tire sizes although listed the same sizearenot the same size so be careful when sizing. I think the best you can do with the stock wheel is to run the dunlop 180. If you want to run a 190 0r maybe even a 200 which I have not tried yet but think it could work without a lot ofcosts and moding is to switch to a Nightrain wheel. The pics here are a Nightrain wheel with a metz 190/50 tire.
Old Dec 4, 2007 | 02:28 PM
Shrug's Avatar
Shrug
Treeex,
did you do that yourself? What mods (if any) were needed to install the Deuce wheel?
Old Dec 4, 2007 | 06:29 PM
treeextractor
Scott, I have posted the part number under "softail Wheel on dyna" and "one more time" on thefitthis forum.
Old Dec 4, 2007 | 10:04 PM
dklozik's Avatar
dklozik
The dynas with the 4.5" wheel, can support a 180. Any wider might fit, but your pulling the sidewalls way in and its gonna handle funny and a possibility of coming off the wheel in a turn (saw it happen to a sport bike with a tire to big for the rim). The 5" Deuce wheel like i have on my bob might hold a 200 ok, but I would probably go with a 5.5" for that width. JMHO
[IMG]local://upfiles/46323/A515698CB88147C68E130AF6546DBF0F.jpg[/IMG]
Old Dec 4, 2007 | 10:21 PM
abcd9906's Avatar
abcd9906
Thanks guys. I appreciate your time.
Sean Maloney
Jun 14, 2017 10:59 PM
lee christopher
Jul 21, 2015 09:51 PM
fergml
Wheels/Tires
Feb 15, 2013 08:37 AM
WARG
Oct 20, 2009 07:04 AM
FatBobber08
Jun 18, 2008 04:44 AM
