Quick Intake Leak Question...
Old Dec 16, 2007 | 01:27 PM
Whiffleboy's Avatar
Whiffleboy
Default RE: Quick Intake Leak Question...
Well, I've done the following to no avail: [ul][*]Replaced plugs[*]Checked for loose connections to the injectors/DFO/O2 sensors[*]Removed the DFO[*]Sprayed some WD-40 around the induction area with no effect[*]Put enough fuel in it to eliminate the fuel line/tank thing Anubisss mentioned [/ul]Doug, the heat management thing would make sense for the weak/soft idling at stop lights, but, I don't think it would address the surging, missing and cutting out symptoms. I'm figuring all the symptoms are related to each other, so, I'll rule that one out.
Short of cutting the casings around the injector harness wires to check for vibratory damage (which I'm not comfortable doing), I don't know what else I can do. Dropping it off at the shop in the morning.
Whiff
pococj
Shovelhead
Apr 27, 2026 11:01 PM
david w mcdaniel
General Topics/Tech Tips
May 22, 2014 06:01 PM
Sundog
Nov 1, 2008 10:50 PM
mattb43
Exhaust System Topics
Apr 15, 2007 08:53 PM
Reffixer
Nov 2, 2005 02:38 PM
