Too Rich
Old Jan 4, 2008 | 06:15 PM
DougsDyna's Avatar
DougsDyna
Default RE: Too Rich
ORIGINAL: mudpuddle
ORIGINAL: DougsDyna
ORIGINAL: Sc07Sbob
with letting it sit and idle,and with the Stabil (forgot to mention that!)
could that be producing the black plugs?[sm=confused06.gif]
I think paulies 07's way is probably most accurate, but hotAs he said,
DougJ
Doug, paulies way is for reading plugs at 60 mph cruising.
But he leaves out one important step.
You need to hit the kill switch as you pull in the clutch,
THEN coast off the road.
Sbob, you're gonna want to wait for the weather.
Or trailer the machine to a qualified dyno man.
mud
Won't argue either point, well said.
DougJ
Old Jan 4, 2008 | 10:15 PM
abcd9906's Avatar
abcd9906
wont coasting at 60 for a length of time without it running hurt drivetrain somewhere? it needs to be running for it to be lubed properly. id be worried about the tranny
Old Jan 4, 2008 | 10:26 PM
mud's Avatar
mud
ORIGINAL: abcd9906
Yeah yeahdon't do it.
Huhnnhnh??
you're kiddin??
right??
mud
Old Jan 6, 2008 | 02:55 PM
cornishman's Avatar
cornishman
You must do a plug chop with your bike at full operating temperature, and under load, up a steep hill if possible with the bike pulling hard, then clutch in and hit the kill switch.
Old Jan 6, 2008 | 03:01 PM
mud's Avatar
mud
ORIGINAL: cornishman
Correct cornish.
For reading the plugs at Wide Open Throttle.
mud
Old Jan 6, 2008 | 03:24 PM
Trotter's Avatar
Trotter
I like the flat roadat normal cruising speed under normal Rideing conditions, do a throttle chop.. Clutch/Kill switch. pull over far enough to keep from getting Killed,Chk Plugs, Install plugs, Start Bike, and ride very carefully over to your choice of tuners with a current Dyno and let him tune the bike....
Adamk1200n
May 24, 2012 01:45 PM
HD101st
Mar 9, 2010 05:14 PM
08FXDC
Mar 31, 2009 05:05 PM
jnb76
May 25, 2007 05:56 PM
stock28
Mar 8, 2006 01:33 AM
