Power Commander/Vista
Old Feb 2, 2008 | 12:02 PM
cornishman's Avatar
cornishman
Default Power Commander/Vista
Hi guys, after many emails and general pratting about with the Fuel Pak i,ve had enough. Ordered a Power Commander from Jamie at Fuelmoto.
Now sod,s law being what it is i,ve read on the fuel injection section that people are having trouble connecting the Power Commander to the bike using Window Vista.
Can anyone enlarge on this? Or is **** creek looming up large?
Old Feb 2, 2008 | 12:09 PM
Smiley51's Avatar
Smiley51
Default RE: Power Commander/Vista
Cornishman If you are getting it from Jamie just tell him all of your mods and he will set it up for you. Thats what I did and have had no problems. Now I'm going to have it Dyno tuned as soon as the f'en weather breaks to get it perfect. Smiley
Old Feb 2, 2008 | 12:26 PM
hk_shooter's Avatar
hk_shooter
I've used my Vista equiped notebook with my Power Commander with no problems. And I am far from computer literate[&:]
What problems have you heard of?
I've got a '06 Bob and a PC USBIII
Old Feb 2, 2008 | 12:34 PM
Cornhusker's Avatar
Cornhusker
First I've heard of problems with Vista and Power Commander. No problems at all here with this setup.
I did read something earlier in another thread about SERT and Vista incompatibility.
Old Feb 2, 2008 | 12:35 PM
cornishman's Avatar
cornishman
This is what i,ve read guys..... hope this works.
:48:48 AM
showPicture("2/1/2008 11:48:48 AM",0,0,0,2810773,264)
airdog
titleAndStar(98,0,0,false,",")
Hang Around
[align=center][/align]
Status: offline
Ive been playing around with my pc3 usb today. and fyi I've already talked to Jamie and a fellow named Kyle @ Dynojet. appears to be 2 problems to me at this point. 1 - software; using a windows vista pc laptop, the driver for the pc3 is not found. per conversation with Kyle, dynojet uses a universal pnp usb driver, but for some reason, this driver isn't found. so there are apparently no drivers to download from dynojet. as it stands right now, with the bike on, and pc3 running I have a "no power commander" in the upper right hand side of the control module display. the puter isn't seeing the pc3. changed usb cables, uninstalled the program loaded by the cd, and downloaded from the fuelmoto site. problem still there. 2 - hardware; MY pc3 has a led illuminated on the left hand bar graph on the pc3 itself. Jamie tells me this is a problem with the unit. after I turn the ignition to the on position it should show a rise and fall, I assume like a self test, but my indicator light stays lit on the second from the bottom led.
has anyone else experienced this? I'm going to give jamie a call in just a few minutes, but being frustrated right now, wanted to calm down a little bit before I gave him a call. I'm sure he'll make it right for me, just wanted to see if anyone else has had this experience with a led indicator.
thanks in advance,
Les
[align=right][/align]
Report | Post #: 1
RE: PC III blues - 2/1/2008 12:56:22 PM
showPicture("2/1/2008 12:56:22 PM",0,0,0,2810773,264)
EZ2Rider
titleAndStar(612,0,0,false,",")
[IMG]https://www.hdforums.com/image/2star.gif[/i
Old Feb 2, 2008 | 12:38 PM
cornishman's Avatar
cornishman
One day i,ll get the hang of this.......... one day.
hdng
Dec 7, 2015 11:26 PM
Mathis
Mar 31, 2011 03:53 PM
FX4
Apr 4, 2009 07:24 PM
bodyman0
Jan 8, 2006 12:23 PM
sknybkr44
May 4, 2005 03:14 PM
