Bottom Mount Headlight on a Super Glide
Old Jan 19, 2006 | 07:13 PM
Randy Page's Avatar
Randy Page
Default Bottom Mount Headlight on a Super Glide
Can it be done?
Any suggestions how?
Thanks
Old Jan 19, 2006 | 09:26 PM
DGlide04's Avatar
DGlide04
Default RE: Bottom Mount Headlight on a Super Glide
It's done on all of the Wide Glides. The headlamp shell is bolted through the lower triple clamp and I don't see any reason that you couldn't do that with a Low Rider or Superglide, although you'd have to find just the right headlamp bucket to fit between the the fork tubes and look good. Could be an interesting look.
Old Jan 19, 2006 | 09:39 PM
RonnieJ's Avatar
RonnieJ
I think it looks better mounted higher.
Mine came mountrd to the bottom and I fabbed a bracket to raise it up to where a " regular" one might be.
This is after
Old Jan 20, 2006 | 12:33 PM
haksaw's Avatar
haksaw
i did this on my fxd. I was told I could just drill a hole in my bottom tree and mount a bottom mount headlight.
I didn't like that idea so I bought a bottom tree, headlight and chrome cover to cover up the top mounting holes (all stock on a sporty custom)
I like the end result.
Old Jan 20, 2006 | 01:34 PM
Randy Page's Avatar
Randy Page
Hacksaw,
That's exactly what I'm looking for.
I'll check the sporty parts section.
BTW- Nice scoot. What type of bars do you have?
Old Jan 20, 2006 | 01:48 PM
haksaw's Avatar
haksaw
I think I may be able to find all the part numbers if I did through my papers if you want them.
(I don't own this bike anymore...unfortunately) The bars were Wild 1 chubbys I think they were 8" rise.
Old Jan 21, 2006 | 01:21 AM
Randy Page's Avatar
Randy Page
I would appreciate that if its not too much trouble.
Thanks
Randy
Old Jan 21, 2006 | 02:25 AM
haksaw's Avatar
haksaw
lower triple tree (xl custom) 45561-87
headlight (xl custom) 67881-96a
headlight mount (xl custom) 67919-96
chrome cover-upper triple tree 67861-96
that should be all you need.
you're probably looking at approx $500-600 for the parts.
Old Mar 17, 2010 | 08:25 PM
DanD's Avatar
DanD
I took the wheel and fender off my superglide,drilled 1 hole,made sure it was close to dcenter,went a little bit oversize to be sure,and mounts the XL custom h/l and standoff.My bike is an 02,i did it back then and it's been fine for 80,000 miles.I also used the chrome top tree cover as well.I went a bit oversize on the hole,so i'd have room to adjust it if need be.I also used a wide trim ring on the headlight,and it resembles a custom teardrop .easy and quick mod.
pretz
Dec 25, 2015 11:24 PM
sparks427
May 30, 2013 10:43 PM
Chad1200
Dec 21, 2009 02:00 PM
motordrum
Nov 30, 2008 09:50 AM
robfaulkner
Nov 29, 2007 07:18 PM
