Levers
Old Feb 10, 2008 | 11:26 PM
ezriderpgh's Avatar
ezriderpgh
Default Levers
o.k., you are all going to wonder if i'm stupid, which i plead the 5th.....but I got some chrome trigger levers on the way. I have changed them on jap bikes many times, no problem. I see Harley doesn't use a bolt and nut to hold theirs on, they use a pin and clip. Other than that am I in for any surprises?
[IMG]local://upfiles/52705/F111BE83A71D49EA9F27D334DEEF6703.jpg[/IMG]
Old Feb 10, 2008 | 11:42 PM
rounder's Avatar
rounder
Default RE: Levers
depends... does your wife know you park your bike in the house to take pictures[sm=joke.gif]
welcome from Tampa Fla...
should have no trouble with the swap as long as you can get the clip out.
Old Feb 11, 2008 | 12:02 AM
mud's Avatar
mud
Default RE: Levers
ORIGINAL: ezriderpgh
ez, you might wanna pick up new circlips beforehand.
Sometimes they stretch out of shape during the removal process,
and once in a while they get misplaced.
Can't remember now if you need to shim the brake light switch
for lever removal.
And don't forget the anti rattle spring.
mud
Old Feb 11, 2008 | 04:33 AM
ezriderpgh's Avatar
ezriderpgh
Default RE: Levers
Thanks guys! And there is no wife...hmmmmm maybe that's why? Hey rounder, I sent you a pm about the bags, how in the world did you mount them without relocating the turn sigs?
[IMG]local://upfiles/52705/FE3C4029FB074046B7CF474018DA9049.jpg[/IMG]
Old Feb 11, 2008 | 07:04 AM
Trotter's Avatar
Trotter
Default RE: Levers
Be very careful on the right side not to rip the rubber booton the brake light switch.... Careful....
Old Feb 11, 2008 | 07:47 AM
jhoyda's Avatar
jhoyda
Default RE: Levers
+1
You can also break the plastic plunger on the brake light actuator. This will result in a brakelight that stays on all the time. I broke my plunger and ended up just removing the switch, the rear brake has a switch too, so I have to be sure I use the rear brake when I stop.
Old Feb 11, 2008 | 07:53 AM
Trotter's Avatar
Trotter
Default RE: Levers
If you rip the boot the plunger is history, It's like a little bigger than a thread.. LOL .... You need to fix that switch... there not hard ... Your delaying the Brake light.. And that's not a good thing...
sf49ers2005fan
Mar 25, 2017 09:05 PM
jbg
Nov 6, 2010 11:48 AM
fastjoe
EVO
Oct 19, 2008 08:09 AM
stanleyc
Jul 16, 2007 05:54 PM
lowleveldriver
Jan 12, 2006 08:16 AM
