Rear Shock Adjust- tool needed?
Old Mar 18, 2008 | 07:45 PM
BoomSoon's Avatar
BoomSoon
Default Rear Shock Adjust- tool needed?
My street bob I have had for a year has the shock settings that came from the factory. I know the big detent is the softest setting. Im not sure what most dyna shocks come set as stock? I want to soften things up a bit and was wondering---is there a way to do it with out the hd tool(spanner) or what?
Old Mar 18, 2008 | 07:50 PM
voyager1's Avatar
voyager1
Default RE: Rear Shock Adjust- tool needed?
You can use a well made strap wrench. NOT a cheapie, it will snap .
Old Mar 18, 2008 | 07:54 PM
Prodriverdon's Avatar
Prodriverdon
I bought mine from Drag Specialties. You must have for load and or passenger weight. I have mine set at 5 and the ride is great.
Old Mar 18, 2008 | 07:59 PM
pwer pla's Avatar
pwer pla
invest in the wrench ($10 i think) that way you don't scratch something and really **** yourself off. Just my .02
Old Mar 18, 2008 | 08:01 PM
Dyna Don's Avatar
Dyna Don
you can turn them by hand but the $10 tool is the best way
Old Mar 18, 2008 | 08:02 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: voyager1
And taking as much weight off the rear suspension as possible will also help.
Old Mar 19, 2008 | 10:47 AM
dyna07custom's Avatar
dyna07custom
I paid 8.00 for mine at the dealer get 1 and keep it aboard I run mine at 4 no pass 5 with passenger when i got mine 1 was set at 1 and 1 at 3 made the dealer check before I left screamed and they set them both to 3
Old Mar 19, 2008 | 11:02 AM
07bobber's Avatar
07bobber
SOME CAN USE THEIR HANDS..I USED A RUBBER OIL FILTER WRENCH STRAP THINGY
Old Mar 19, 2008 | 11:10 AM
RAWHIDE07's Avatar
RAWHIDE07
Buy the wrench,you will need to try various settings until you are satisfied and as you get more miles on the bike you will be resetting the shocks.
Old Mar 20, 2008 | 04:40 PM
BoomSoon's Avatar
BoomSoon
Thanks all. YEP, 10 bucks at a dealer. Pretty flippin simple and useful tool. Later
