What to expect?
Old Mar 19, 2008 | 02:45 PM
Tuggin's Avatar
Tuggin
Default What to expect?
I have a chance to buy a 98 Super Glide w/ about 22k miles. It looks like it's been well cared for. Oil was changed regularly including primary and trans oil. What can I expect from the engine, like chain tensioners, top end wear etc? What about the rest of the bike in general.I have never owned a HD and I'm not looking to buy a bunch of problems. I would appreciate your feedback.
Old Mar 19, 2008 | 04:17 PM
mfuchs2004's Avatar
mfuchs2004
Default RE: What to expect?
Was the bike regularly ridden or was it stored?
Old Mar 19, 2008 | 04:56 PM
Tuggin's Avatar
Tuggin
The current owner has had it for eight yrs. he rode it regularly when he first bought it less as the years went by and as I understand it not much at all the last couple of years.
Old Mar 19, 2008 | 05:31 PM
Tuggin's Avatar
Tuggin
I could really use some input here! I have to make a decision on this bike soon!
Old Mar 19, 2008 | 09:23 PM
mfuchs2004's Avatar
mfuchs2004
Should be a reliable bike, unless it's already got an issue. Most likely things that'll come up on a bike that's been sitting:
1. Tires should be given a VERY careful look. I'd consider wanting new rubber.
2. Brakes and brake cylinder/piston issues. Seals can rot.
3. Rotton fuel damage. Carb probably needs a cleaning at the very least. Might as well do the filter.
4. Run a compression test.
5. Battery shot.
6. Other gasket and seal leaks, cable inspections.
Take it to a good shop for an inspection and tune. If the price was right, it'd be in my garage right now.
HD is one of the most reliable bikes over the long run. Yea, yea, beemer guys, I know you don't wanna be left out. You hardly ever see a metric bike with 100K - I see harleys all the time that've spun the clock over. I was a Kaw guy for years. A Kaw with 50K was past ready for a full rebuild. An SG is just getting "seasoned." Regular maint, buy the SM, good gas, keep the battery and tires tended, and you're good to go. Most likely you'll spend ten times as much on crap...I mean mods...then you'll ever spend on repairs.
Old Mar 19, 2008 | 10:08 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: mfuchs2004
Boy oh boy you aren't kidding............
martin10
Sep 4, 2018 08:22 AM
SoCalHDMC
Milwaukee Eight (M8)
20
Apr 28, 2018 10:02 PM
Steve635
Jun 17, 2015 03:50 PM
msgtarmor
Sep 26, 2007 09:42 PM
troglodyte
Aug 14, 2005 11:45 PM
