6th Gear Indicator Light
Old Mar 19, 2008 | 08:18 PM
Topspin's Avatar
Topspin
Default 6th Gear Indicator Light
Do I have a 6th Gear Indicator Light on my 07 FXDWG? Seems I heard that mentioned somewhere.
If so... I can't find it.
Old Mar 19, 2008 | 08:29 PM
Wobbie1775's Avatar
Wobbie1775
Default RE: 6th Gear Indicator Light
yeah you should have one. its a green number 6 in the speedo, at the bottom....if you get the light to hit it just right, you may be able to see the outline of the 6 with out the acc. on. if you need a pic, i can get one, but i am in the middle of putting apes on, so it may be a few days.
Rob
Sgt/USMC/0311
Old Mar 19, 2008 | 08:47 PM
DougsDyna's Avatar
DougsDyna
Put it in 6th and find outSorry couldn't resist..........
DougJ
Old Mar 19, 2008 | 10:30 PM
pwer pla's Avatar
pwer pla
Bottom left on spedo, not real bright hard to see in direct sunlight.
Old Mar 20, 2008 | 05:20 AM
domenicp7's Avatar
domenicp7
The 6th gear light is activated by the ECM based on speed and RPM. If its not coming on I would look into it. Have you installed an aftermarket tuner?
Old Mar 20, 2008 | 07:48 AM
BLade1127's Avatar
BLade1127
What fuel management system are you running? A buddy of mine has the ThunderMax, and he lost the indicator light and low fuel light when it was installed.
Old Mar 20, 2008 | 09:59 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: DougsDyna
DougJ
Yeah....at nightime.........
Old Mar 20, 2008 | 10:03 AM
dynaglide07's Avatar
dynaglide07
yes on bottom lft side of glass when you are in 6 it will light up. if not check wiring.
Old Mar 20, 2008 | 10:51 AM
Topspin's Avatar
Topspin
Found it with the help of the Owner's Manual and you guys.
Mine don't light up.
Old Mar 20, 2008 | 11:07 AM
dyna07custom's Avatar
dyna07custom
ORIGINAL: pwer pla
+1 real hard to see in direct sunlight
soft 02
Aug 6, 2013 01:31 PM
redmonster13
Feb 11, 2011 09:56 AM
soft 02
Dec 16, 2010 07:59 PM
stevieg
Feb 22, 2008 11:23 PM
badlands
Jul 15, 2007 11:55 AM
