3 Rear shock adjustment questions...
Old Mar 23, 2008 | 03:39 PM
Topspin's Avatar
Topspin
Default 3 Rear shock adjustment questions...
1. If you soften the shocks to lowest setting will it lower the bike?
2. Which is the softest setting ? 1 or 5?
3. Do you need a spanner wrench to do this or could it be done by hand?
Thanks for letting be be a lazy azz. I'm sure the answers are there if I get up off my azz.
Old Mar 23, 2008 | 04:02 PM
ssls6's Avatar
ssls6
Default RE: 3 Rear shock adjustment questions...
The "1" setting is the least amount of preload. The bike should ride lower with your weight but may not sit lower when you're off the bike. The downside of running too little preload is bottoming out the shock.
Old Mar 23, 2008 | 04:13 PM
oldsporty1's Avatar
oldsporty1
What ssls6 said, most of the time you need a spanner.
Old Mar 23, 2008 | 04:28 PM
BoomSoon's Avatar
BoomSoon
Ditto but also. I asked this recently on a post and it really helped. GET the wrench. I did at an HD dealer- ten bucks. someone suggested doing it by hand or with a strap wrench. If your out get one it makes it a snap. Turn the bottom barrel counter-clock(if your behind the bike) and when it pops into the "1" setting it really pops. On my fxdb the teeth on the shock have a barrel around it that kind of hides it all but you can look up it and see what I mean.
[IMG]local://upfiles/54962/656175C8C137476C9931BE611E6B71C9.jpg[/IMG]
[IMG]local://upfiles/54962/824D8C2FB4284F639AB5F1BB1690AC27.jpg[/IMG]
Old Mar 23, 2008 | 06:58 PM
dynaglide07's Avatar
dynaglide07
if you ride alone set it at three best spot . if with some one else use #5 if you both are heavy. get a shock wrench!
Old Mar 23, 2008 | 07:00 PM
pwer pla's Avatar
pwer pla
NO
One
Yes
Hope this helps
Old Mar 24, 2008 | 09:02 AM
SPECIAL ED's Avatar
SPECIAL ED
Yes it will make it lower.
Mine came set at 1 the lowest setting I guess because the guys that set up the bike thought that looked the coolest, it rode like crap.It bottomed out so fast it felt like a rigid.I felt like the stock Street Bob shocks worked best one notch down from the max.And yes you should get a wrench.
Old Mar 24, 2008 | 09:53 AM
Prodriverdon's Avatar
Prodriverdon
Never ride with a setting of one. You will bottom out on bumps. It will make a world of difference to go up the" ladder " in settings. Everyone has there own opinions on what they have,only you will know after you ride. BUY THE TOOL.........
Old Mar 24, 2008 | 10:29 AM
dyna07custom's Avatar
dyna07custom
ORIGINAL: ssls6
thats it nothing else left to say except if you bottom shocks out you eventually will destroy them
Booey424
Sep 23, 2016 11:29 AM
Z3ro1983
Jan 22, 2016 05:35 AM
BobZ06
Aug 24, 2012 06:42 PM
Ventana
Jul 11, 2011 10:10 PM
mike56
Mar 6, 2010 05:27 PM
