mini ape install
https://www.hdforums.com/m_3034163/tm.htm
All good advice above, the link below is the one I used when changing mine out a few weeks ago.
You won't need the first few stepsif going with themini apes, but still good info if you plan any wiring changes or go internal in the future. (I should have, maybe next year)
https://www.hdforums.com/m_1328001/tm.htm
As mentioned, it really is easier than you think it is, I kinda put it off a bit because of the clutch and brake cable changeout (you'll need to change out idle and throtttle too, but are they even easier).
Everyone says the brake changeout is in the manual, (which is a great investment if you don't have it), but this thread gave me more info than the manual on the brake line.
I hated the original buckhorns on the bike, very uncomfortable bending my wrists and arms inward. When changing to the mini apes, I made it work temporarilly with the original cables, bending the brake line, and having the others tight before investing the extra cash on new cables.
Turns out I like them way better, and invested the extra dough for SS Braided cables instead of the stock mini ape cables. It was only $40 more for the SS setup all around over the stock, so why not?
Oh yeah, you'll need a decent snap ring plier, mine is about 30 years old and emergency modified on the job, that would have made the clutch cable change out a little easier for me with a small investment on a new set of snap ring pliers, maybe next time...
