Tmax Help!...FIXED
Old Mar 29, 2008 | 08:53 PM
rok312's Avatar
rok312
Default Tmax Help!...FIXED
Posted this in the Tech Forum https://www.hdforums.com/m_3118960/tm.htm
..but thought I'd throw this out to my Dyna brothers. Any ideas why my Front and Rear AFR monitors are showing a 9.30 AFR - despite a target of 13.0 - when the bike is running? Yes, I've initialized and checked connections and checked to make sure closed loop is turned on, etc, etc. I'm using base map 393 (as I've seen other Dyna owners with similar setups use successfully).
I'm at a loss..
Old Mar 29, 2008 | 09:43 PM
hk_shooter's Avatar
hk_shooter
Default RE: Tmax Help!
No idea why.
It does sound real 'fat' (rich)
How does it run?
Old Mar 29, 2008 | 10:30 PM
rok312's Avatar
rok312
ORIGINAL: hk_shooter
No idea why.
How does it run?
Despite this issue, it runs really well. Idles great, no popping on decel (just installed Bub Seven 2-2 full system), pulls really strong. However, it appears the O2 sensors are not working - so no tuning is taking place.
Old Apr 2, 2008 | 01:38 AM
rok312's Avatar
rok312
Fixed!!! https://www.hdforums.com/fb.asp?m=3138367
Woohoo!
Old Apr 2, 2008 | 07:57 AM
Airborne350G's Avatar
Airborne350G
The link is not working....
https://www.hdforums.com/m_3118960/m...tm.htm#3138367
ORIGINAL: rok312
Woohoo!
tj66
The Dyno Room
Jun 4, 2016 10:35 AM
Stych
May 22, 2014 10:28 AM
newdep332
May 15, 2010 06:50 AM
The Nev
Mar 4, 2008 11:09 PM
bdavis385
Nov 11, 2007 11:39 PM
