Question for you Mechanic Types
Old Mar 30, 2008 | 05:17 PM
jayhantz7's Avatar
jayhantz7
Default Question for you Mechanic Types
I thought I would turn you awesome people in the forum before I take it to a stealership. So while riding, I am getting a more noticeable shake. I can feel it in the handlebars and the footpegs mostly, and it hasn't shook like that in my time of riding it. For instance, while riding and I decide to slow down before a light, while slowing I am getting the shake, and then it slowly goes away. The shake is also there at higher speeds as well. Don't know if it is something I should worry about or something I can probably fix on my own. Thanks for the help!
Old Mar 30, 2008 | 05:28 PM
Gilly's Avatar
Gilly
Default RE: Question for you Mechanic Types
How many miles on the bike and on the front tire?
First to-do is check tire pressure, and check front tire for cupping/ragged edges on tread.
Gilly
Old Mar 30, 2008 | 05:37 PM
IBSandy's Avatar
IBSandy
6th Gear
Hi,
From what you are describing, it sounds like:
1. Your front wheel and/or bearings are worn.
2. Your Triple Trees are loose....I say this because you are getting the vibration on acceleration and deceleration. Check your fork stem nut for tightness.
HTH,
Sandy Jacobs
Old Mar 30, 2008 | 06:18 PM
jayhantz7's Avatar
jayhantz7
Tires are no factor. Have a new back and front recently installed, about 1,000 miles ago. Will look at the triple trees later tonight and see if that's the problem. Thanks for all your help
Old Mar 30, 2008 | 06:23 PM
wall018's Avatar
wall018
Jay, there is a proceedure for adjusting your steering head bearings known as the "fall-away" adjustment. If you have or can get access to a HD service manual it is outlined in the maintenence section. Basically you are adjusting the tension on the bearings but there is other things in the proceedure that must be done to do it correcetly, but it can be done withbasic hand tools and skill level.Good luck
Old Mar 30, 2008 | 06:28 PM
Sec Super Glide's Avatar
Sec Super Glide
You lost a wheel weight??.
Old Mar 30, 2008 | 06:32 PM
rbabos's Avatar
rbabos
Could be a warped rotor with a tight caliper. Caliper may even be at the point of seizing and as the rotor heats up it starts grabing causing the shaking.
Ron
Old Mar 30, 2008 | 06:45 PM
0ut1aw's Avatar
0ut1aw
I vote for the wheel weight
Always check the simplest first. I spent an hour checking witing after replacing my handlebars because my brake light didn't work just to find it was the bulb....
Old Mar 30, 2008 | 07:21 PM
IBSandy's Avatar
IBSandy
6th Gear
For grins....look at the front motor mount and see if it is "sitting" low. All of the above ideas are excellent suggestions.
Sandy Jacobs
Old Mar 30, 2008 | 07:25 PM
Topspin's Avatar
Topspin
Spokes loose? Ever had 'em serviced?
Do you clean them with shoelaces? That will loosen them everytime.
I got a $5 bill saying that this is your problem.
