Riser size
Old Apr 21, 2008 | 11:59 AM
Cornbread's Avatar
Cornbread
Default Riser size
06 Street bob- Wanting to get new risers and I don't know what to look for in terms of bolt size and thread type. Also, can i change out the bolts completely, if so what are my limitations?
Old Apr 21, 2008 | 12:06 PM
Bobber Rider's Avatar
Bobber Rider
Default RE: Riser size
Cornbread
if you're referring to the riser bolt dimensions (the large bolt that holds the risers to the top tree)
then all standard HD (both OEM and aftermarket) rises use 1/2"-13 UNC bolts.
they should be minimum Grade-5 bolts.
thread and stem length depends on the specific application/riser combination
Old Apr 21, 2008 | 12:43 PM
Cornbread's Avatar
Cornbread
Great, thanks bro
Old Apr 21, 2008 | 12:50 PM
fiend138's Avatar
fiend138
Are you planning on puting slugs inder your Risers or someting?
Old Apr 21, 2008 | 04:10 PM
Cornbread's Avatar
Cornbread
what do you mean slugs?
Old Apr 21, 2008 | 04:21 PM
fiend138's Avatar
fiend138
Some people have raised there bars slightly like an inch or so with a spacer/slug that goes between the top tripple tree and the riser. I thought maybe thats why your were asking about the bolt size.
Old Apr 22, 2008 | 03:55 AM
Cornbread's Avatar
Cornbread
No slugs. Last year I put cheap 16 in apes on to see if I was liked the height. I left enough slack in the cables to be able to go up at least another 2 if not 4 inches. I love the height so now I am going to spend some money on some cool risers and bars.
Old Apr 22, 2008 | 08:27 AM
twofish's Avatar
twofish
4” Risers info:
https://www.hdforums.com/m_3048551/tm.htm
3”Risers info:
https://www.hdforums.com/m_3099943/tm.htm
Jersey Drew
Apr 4, 2016 08:58 PM
Voony
Aug 4, 2011 04:28 PM
Xenomorph
Feb 1, 2010 07:32 AM
lchen6
Sep 29, 2008 12:35 PM
CHEESE
Jul 29, 2006 03:40 PM
