Under pressure
Old Apr 22, 2008 | 11:28 PM
WS6 Formula's Avatar
WS6 Formula
Default RE: Under pressure
If you unbolt the top mount and push the engine side to side, does it feel like the engine is hitting up on something in the frame? Are the shocks set at the same preload? What about undoing the lower shock bolts and see if there is any difference. Are swing arm bushings good? Front fork tubes set at the same height? Bikes history, accidents, damage? I'm running out of ideas here.
Old Apr 23, 2008 | 06:17 AM
SLICK SALZ's Avatar
SLICK SALZ
Thank you for pointing me in a direction. Finely. Motor does not hit the frame when top link is removed and fork tubes are at the same height as for the rest as soon as I get home from work Now ive got something to check. Ive been out of ideas too. I bought the bike just over a year ago for 13k and cant ride it because of this strange vibration , had it to 2 dealers and they cant tell me a thing. Im pulling my f-ing hair out and am ready the cut the bike up!!!! any and all ideas help here guys!!!! WS6 Formula has given me some were else to look. Ill let you guys know how I make out tonight. PLEASE PLEASE PLEASE feel free to call me this may be easier and much faster!! Ill even pay the phone bill, Im at my wits end.
Thank you so much guys
Adam cell (518) 858-6221
Im always up till midnight
Old Apr 23, 2008 | 06:36 PM
SLICK SALZ's Avatar
SLICK SALZ
well I pulled the rear shocks off and put some slack in the belt to take all tension off the rear wheel and swing arm. I noticed some play the rear wheel-left to right like your checking for a loose tie-rod on a car. I guess Ill do the bearings. Then I removed the wheel to take all the weight off the swing arm. Sitting on the ground at the rear of the bike looking at the rear mount I got some play(very little) from left to right . to take it a step farther I removed the chrome cap that covers the head of the pivot bolt on the right hand side of the swing arm and inside I found a bunch of ground up material that feels like Teflon tape. I wonder if this is a tell tale sigh of the bushing going bad?? I also see that my rear tire is cupped on both sides. Could all these things be the reason I cant get the wheels vertically aligned ?? My original problem has been a bad vibration around 2000 rpm during acceleration and\or deceleration do you think these problems could be the cause??
Old Apr 24, 2008 | 05:58 AM
SLICK SALZ's Avatar
SLICK SALZ
any thoughts on the swing arm bushing guys?
fshaw
EVO
30
Sep 21, 2018 08:14 PM
mang0
Aug 3, 2016 11:26 AM
jlr1125
Oct 8, 2008 09:22 PM
Roadking1679
Nov 14, 2005 02:03 AM
