FXD is a Dyna. FXR is...well, an FXR. Totally different frames. The Dyna replace the FXR because it was cheaper to produce. Whether that was an improvement is open to interpretation.
+1 That's what I've heard too. FXD is not necessarily, specifically an evolutionary climb above the FXR but one can see obvious similarities. And when you go into dealerships, you see that the Dyna/FXR accessories are on the same wall. But, I've heard they stopped making the FXR because the frame is more expensive to produce and there wasn't enough demand to justify it. You can still buy FXR frames though, just not from HD.
I believe FXR's had the engine mounted to 3 rubber mounts where the Dynas have 2. The Dyna chassis was supposed to be engineered better and be an improvement over the FXR, but lots of people still preferred the FXR in handling, at least in the beginning. Now that the Dyna chassis has been re-designed twice since then you'd be hard pressed to get me to believe an FXR is better in any way than a new Dyna, but they're still classic bikes.
I now own and have owned several dynas. Right now an 08 FXDB. But I've gotta say.....nothin' compares to an FXR. Harley shoulda never discontinued such an awesome machine. But, in their infinite wisdom, they did. Mostly because all of the yuppies wanted softails AND the FXR was an expensive frame to produce. Eric Buell was the creator of the great FXR frame. So, where do ya think the handling came from?
FXR's also weighed a LOT less than the current FXD's; that always helps handling...but, I'd take a HD twin-cam over a HD Evo for a hop-up starting point. Everything inside the cases is stronger and the tranny is bolted to the back of the engine.....I seriously considered an FXR or building one with a twin cam and an aftermarket frame before I bought my FXDXT, stripped it down to the frame, and re-built it the way I wanted it.....
'01 FXDXT
103 by HQ
some aluminum and some composit and some other stuff
620lbs wet weight
goes good
handles OK
I have experience with the old FXR and it was a good bike. It was not without issues, however.
It was still an early version of the rubber mount system and, when pushed hard in the twisties, it also liked to wiggle around. The guy who started True Track was an early supplier of kits to stiffen up the rubber system. The procedure involved replacing rubber mounts with metal ones. Another supplier offered stainless struts that rigidly attached the entire swingarm to the frame and circumvented the rear rubber mounts.
I've been there and done it all with those bikes.
The FXR was not replaced in an effort to build something cheaper, lol. The Dyna was a highly engineering bike that was introduced mainly to address aethetic (looks) issues with the FXR. FXR fans now may not remember but, during it's time, there was market resistance to it because many people did not like the looks of the triangulated frame sections on the sides or the high backbone under the seat. They thought it looked too japanese or non-Harley.
The Dyna's development was actually an expensive one that offered a bike that looked more like the earlier "real" Harleys, e.g. the FX series but also retained the smoothness of the rubber mount system.
Again, the rubber mount running gear on the Dyna presented similar handling issues as the FXR when pushed hard. Most Harley riders, however, did not ride this way so the curvy road squirm was not a an issue that trumped what most considered the better, more traditional look of the Dyna.
The current Dyna models are improved over the original ones and, with proper suspension mods, e.g. jacking the rear end up and fitting better shocks, cartridges in the front forks, drive-train stabilizers, lower and more narrow handlebars, the Dyna can be made to handle as well or better than any Harley ever made, including the FXR. They can rival many of the european bikes when set up for such performance.
her bike is faster and handles way better the brakes stop better and it just hauls ***.
I would have not bought my dyna had I rode an fxr previously.
fxr is a rad bike
ask this guy which one he thinks is cooler http://www.youtube.com/watch?v=6adstrKHPc0
