06-08 Wide Glide Riser question
Old May 23, 2008 | 10:07 AM
Airborne350G's Avatar
Airborne350G
Default 06-08 Wide Glide Riser question
When you look down on the risers you see that the cap is not centered over the bolt. I have to ask is yours toward the front or to the rear? Reason I ask is that I read that some have changes the neck washer without taking off the handle bars and I cannot get a socket on the nut without taking th ehandle bars off.
Old May 23, 2008 | 10:25 AM
ssls6's Avatar
ssls6
Default RE: 06-08 Wide Glide Riser question
I had to remove my bars to change the steering stem nut washer. I had a friend hold the bars while I did the work. I also adjusted my fall-away at the same time (which I would recommend everyone do). If you do this, put the bars back on and snug the cap screws until the fall-away is set. Then pull the bars again and torque the steering stem nut to spec.
Old May 23, 2008 | 10:31 AM
Airborne350G
Thanx. Just made me wonder if my dealer put the risers on wrong. I have seen the clutch cable run in two different places. One goes over the handle bars and then behind them and down infront of the tank. The other way is the clutch cable stays infront of the handle bars all the way. Mine is run the first way.
Old May 23, 2008 | 11:34 AM
mud's Avatar
mud
ORIGINAL: Airborne350G
Offset is toward the tank Greg.
I had to remove bars for the washer changeout.
I have my cable in front of the bars.
mud
Old May 23, 2008 | 11:38 AM
Airborne350G
Thanx for the pic Mud. Now to get my washer and fix my clunk..
jcbagger
Sep 17, 2017 02:39 PM
Mattster
Mar 14, 2016 08:05 PM
DocO
Nov 21, 2011 03:42 AM
scooty
Jul 6, 2011 10:20 PM
jhart433
May 3, 2009 07:59 AM
