Speedometer moisture
Old Mar 2, 2006 | 04:47 PM
kevinb62's Avatar
kevinb62
Default Speedometer moisture
Has anyone had their speedometer get mosture inside the lens?
Had my Bobber parked outside for a few hours at night and the dew
was pretty bad. After wiping it off I noticed the moisture under the lens.
Would this be covered under warranty? IF not, any way of fixing the problem?
I would hate to see what will happen if I ever get caught in the rain.
Old Mar 2, 2006 | 05:27 PM
Rhubarb's Avatar
Rhubarb
Default RE: Speedometer moisture
They all seem to do it.
Its water-proof(resistant) but mositure does get inside.
I'm more worried about corrosion in a few years. I have ridden in the rain several times now and no water gets inside.
Old Mar 2, 2006 | 05:30 PM
Punky Brewster's Avatar
Punky Brewster
This seems to be a common problem,& no it's not covered under your warranty
Old Mar 2, 2006 | 06:33 PM
DCRANER's Avatar
DCRANER
This is fixed quite easily. At about 130 MPH on a warm day for around 3 minutes and all will be clear & dry. [sm=gears.gif][sm=oopssign.gif]
Old Mar 2, 2006 | 07:24 PM
dl03's Avatar
dl03
there is a huge difference between water proof and resistant. resistant is,"well,water could get in....." water proof is,"no way could water get in."
if i were u, i would definately make some waves to the dealer. its bran new and should not be doing this. the gasket that goes around the bezel prolly has been pinched or compromised some how. easy fix though.if they won't repair it just put a new gasket in it.
Old Mar 2, 2006 | 07:41 PM
Punky Brewster
ORIGINAL: DCRANER
ROTF.........I do that all the time,I thought I was the only one
Old Mar 2, 2006 | 08:04 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: kevinb62
What do you want after spending $20,000, perfection? It's hard to believe what we put up with to own a Harley especially after spending that much money, and it's also hard to believe that Harley can't fix the problem. We haven't had any rain or moisture for so long in the Phoenix Metro area that I don't know if mine would have that problem or not.
Old Mar 2, 2006 | 08:11 PM
JimboFXD's Avatar
JimboFXD
Yeah it has happened to mine. I got pissed at first but it dried out on it's own...then I had a little spider find it's way in there. He rode the needle for awhile and spun a little web. He found his way out and the web is gone.
ch54
2014-2024 Touring Models
Jul 26, 2017 08:51 AM
C908
Jun 19, 2015 06:26 AM
jcannady
Jul 2, 2013 06:49 PM
pugs
Jul 14, 2009 06:58 PM
firestar99
Oct 10, 2006 02:38 PM
