Wrapping chrome thunderheaders tomorrow - Tips?
Old Jul 17, 2008 | 08:43 PM
AdrianVall's Avatar
AdrianVall
Default Wrapping chrome thunderheaders tomorrow - Tips?
Hey guys, Im wrapping my chrome thunderheaders tomorrow with black wrap, and I was wondering on whats the best method of getting this done. I will have another guy helping me out, so it will be nice and tight, but I just want to know what else needs to be done? Ive heard they need to be soaked before being wrapped? What about spraying them with high heat paint? I was thinking of wrapping them up to the bracket, then spraying the rest with high heat BBQ paint to finish the black look. Any suggestions/opinions? Thanks guys!
Old Jul 17, 2008 | 09:43 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: Wrapping chrome thunderheaders tomorrow - Tips?
I just re did mine not too long ago
Old Jul 17, 2008 | 09:46 PM
SPECIAL ED's Avatar
SPECIAL ED
I started above the O2 sensors and concentrated most of the wrap at the hottest part of the header the rear head pipeTrying to keep my posts short so they go through.
Old Jul 17, 2008 | 09:48 PM
SPECIAL ED's Avatar
SPECIAL ED
The first time I did it I started below the O2 sensors and covered 1/2 of the tape each time around.This gave me plenty of tape to reach the muffler but didn't block much heat.
Old Jul 17, 2008 | 10:09 PM
last saint's Avatar
last saint
I used to soak it in water, but then I realized it didn't really matter. It just helps get it a little tighter and makes a helluva mess.
D
Old Jul 17, 2008 | 10:10 PM
last saint's Avatar
last saint
I actually wrapped mine with the pipe on the bike. It kind of helps a little rather than taking it off and trying to hold the pipe ANDheader wrap at the same time.
Old Jul 17, 2008 | 10:13 PM
Bluesssman's Avatar
Bluesssman
Remember, wrapping pipes will cause them to deteriorate faster.
Old Jul 17, 2008 | 11:24 PM
BeavisRules's Avatar
BeavisRules
http://www.bikernet.com/garage/PageV...asp?PageID=750
&nbsp\\;
It is really easy!!
&nbsp\\;
Old Jul 17, 2008 | 11:54 PM
ezriderpgh's Avatar
ezriderpgh
ORIGINAL: Bluesssman
&nbsp\\;
Pipes are designed to last the life of the bike but as Bluesssman stated, wrapping will cause deterioration. You should research this before doing it, unless you don't care [8D]
Old Jul 18, 2008 | 09:56 AM
JRK5892's Avatar
JRK5892
with a thunder header you want to keep the heat to the motor, wrap the pipe! soak it and use 2 people..on to pull the wrap tight and hold it an one to hold the pipe, i even run the wrap around a pole to get more leverage to get it real tight
