checking your oil cold vs hot
Old Aug 3, 2008 | 07:46 PM
imcworth's Avatar
imcworth
Default checking your oil cold vs hot
ON my 08 Fat Bob...The manual say's... that you can do a cold check of your engine oil which should read at the half mark on your dip stick...then when you warm the engine to normal temps the oil&nbsp\\;will rise to the full mark..Mine however there is no difference between cold check and HOT check..or if there is its very small difference that I can't really see with the naked eye....anyone else see the rise from half mark cold..to full mark.
Old Aug 3, 2008 | 07:48 PM
jrsmith_80's Avatar
jrsmith_80
Default RE: checking your oil cold vs hot
my 07 LR is the same way
Old Aug 3, 2008 | 07:54 PM
paul s's Avatar
paul s
Don't expect to see too much expansion with 4 qts. It's summertime and it's more than likely warm already. Look to see more difference in the winter.
Old Aug 3, 2008 | 08:03 PM
imcworth's Avatar
imcworth
4 quarts ???? the manual say's&nbsp\\; 2.5 quarts .....
Old Aug 3, 2008 | 08:04 PM
FATBOB.'s Avatar
FATBOB.
half way between add and full....cold engine..cant go wrong..have fun riding...[sm=biker.gif]
Old Aug 3, 2008 | 08:15 PM
paul s's Avatar
paul s
Sorry about that I was thinking about my other bike when I posted that.&nbsp\\;\\\\\\; It should be 3qts. dry, 2.5 on oil change.
Old Aug 3, 2008 | 08:28 PM
96 Wide Glide's Avatar
96 Wide Glide
I dont see any difference in hot/ cold level on my EVO either.
Old Aug 3, 2008 | 08:34 PM
maddghost's Avatar
maddghost
when my engine is cooled off say 4 ,&nbsp\\;5 hours or overnight it reads&nbsp\\;one square down from the full hot mark,and when hot straight on the full line.
Old Aug 4, 2008 | 06:52 AM
seaox's Avatar
seaox
2.5 quarts of oil basically doesn't expand with heat or contract with cold.
&nbsp\\;
An oldtime wrencher explained that a lot of engines will allow some oil to drain back from the oil reservoir into the engine sump after sitting for a period of time. After start up&nbsp\\; the oil is pumped up to the oil reservoir and then you get a correct reading.
&nbsp\\;
My 03 sportster when it sits over a winter will show&nbsp\\;1 or more quarts low on the dipstick. It was a fresh oil change before storing. I start it up and a few minutes later, after shut down, I have a full level on the dipstick. (There is a fix for this on the forum FYI). If I added oil before start up I'd be overfull by 1 or 2 quarts.&nbsp\\; My 03 Wide Glide does not do this.
Old Aug 4, 2008 | 06:58 AM
Newhawk's Avatar
Newhawk
Mine is the same hot or cold. 07 DWG
nightsterO
Jul 14, 2014 12:42 AM
UltraClassicElectraGlide
May 2, 2014 03:14 PM
Ron750
Aug 30, 2013 02:29 PM
MadMaximus
Apr 24, 2011 07:40 AM
tenn.vol.
May 26, 2010 08:17 PM
