Fat Bob forward control extensions?
Old Aug 4, 2008 | 02:51 PM
caldyna's Avatar
caldyna
Default Fat Bob forward control extensions?
&nbsp\\;&nbsp\\;&nbsp\\; Does anyone out there have or has seen forward control extension kits for the Fat Bobs? The standard wideglide kits do not fit. I'm 6'5" tall and a little extra leg room would be nice. Thanks in advance.
Old Aug 4, 2008 | 05:10 PM
0ut1aw's Avatar
0ut1aw
Default RE: Fat Bob forward control extensions?
I just made some of my own and posted it in the under 50 busks post but regular dyna would fit i would think
Old Aug 4, 2008 | 07:13 PM
Shizims's Avatar
Shizims
I'm 6'5 as well, I put the kury forward control highway peg mounts on.&nbsp\\; I don't mind the stock forward pegs for regular riding but when I'm cruising the highway for long periods the the highway pegs give me a nice place to stretch out and relax.&nbsp\\;
Old Aug 4, 2008 | 08:13 PM
jefflesh's Avatar
jefflesh
3rd Gear
I am 6'1" and I just bought a Fat Bob about two weeks ago. Within a week I drove up to northern Michigan, about 270 miles. I ended up putting on about 350 miles that day and the only thing that hurt were my inner thighs because the forward controls were not long enough. That said, much better than the crotch rocket bikes I have owned in the past. Needless to say, i was wondering the same thing, I am glad I found this post!
Thank you for your time.
Sincerely,
Jeff
Old Aug 4, 2008 | 09:06 PM
0ut1aw's Avatar
0ut1aw
there is no frame difference between a FB and a SB or LR is there
Old Aug 4, 2008 | 09:08 PM
0ut1aw's Avatar
0ut1aw
pretty easy to make your own
&nbsp\\;
heres mine mounted
&nbsp\\;
[IMG]local://upfiles/19128/89AB6B868ADD40B8907FA0306B0D5E4C.jpg[/IMG]
Old Aug 4, 2008 | 09:13 PM
caldyna's Avatar
caldyna
&nbsp\\;&nbsp\\; &nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; I don't think there are any difference with the forward control mounts but that does'nt seem to be the problem.&nbsp\\; It's the rear brake linkage that is my main concern. I have a kury extension kit on my 02 fxdwg and the brake rod configuration is different.
Old Aug 4, 2008 | 09:21 PM
0ut1aw's Avatar
0ut1aw
Wide glide is different my LR has a straight brake rod i just cut the bolt off the end tapped it and used all thread to extend 3 in
Old Aug 4, 2008 | 09:27 PM
0ut1aw's Avatar
0ut1aw
harley shows same part num 41962-03 for the stock rod for 03 up dynas and WGs
&nbsp\\;
Is your rod straight on the FB
Old Aug 5, 2008 | 04:45 AM
caldyna's Avatar
caldyna
The wideglide kit won't fit on the Fat Bob with the stock header pipe. I just installed a set of V&amp\\;H short shot staggered on the FB and I think that the extensions on my 02 fxdwg might fit on the Fat Bob. I'm going to try a swap this week when I get a little time. I'll post the results when I'm finished.
stagolee
Oct 10, 2010 02:44 PM
malcolm.rowan
Nov 26, 2008 02:41 AM
BoomSoon
May 20, 2008 01:34 PM
Bat
Apr 8, 2008 08:24 PM
rbt1548
Apr 2, 2008 06:59 PM
