removing strut covers
Old Nov 15, 2008 | 09:18 AM
nevil's Avatar
nevil
Default removing strut covers
What's the best way to remove the strut covers on my 07 Street Bob? Either will leave off or paint black. Just changed out the shocks to black 440s, was easy enough. I don't have a jack but will get one if needed. One of my concerns was the turn signal wiring. The shop manual isn't too clear on that, but looks like they connect in the taillight.
Old Nov 15, 2008 | 09:32 AM
rounder's Avatar
rounder
without a lift you may not be able to get the bolts out that attach the signals(many need to drop the tire down)... other than that remove strut bolts and upper shock mount and they come right off... wiring will not be exposed.
Old Nov 15, 2008 | 09:58 AM
jmpancoast's Avatar
jmpancoast
Remove the tail light lense. There you will see where the signals plug into the junction box. Unplug them and and pull the wiring through the holes in the struts and covers. The harness plugs are small enough to fit through these holes.
Old Nov 15, 2008 | 10:10 AM
red devil's Avatar
red devil
+1 on all of the above. I replaced a signal on the right side rear and the wiring is all in the taillight. Easy plug & play. Didn't have a lift at the time but would of been easier to hang the wires under the fender.
wichitaks
Apr 8, 2014 03:06 PM
vtwin47
Dec 30, 2010 02:22 PM
jousley
Dec 29, 2009 12:11 AM
Fupl18
Feb 7, 2009 11:02 AM
Ex11b
Feb 23, 2007 12:10 AM
