Rear wheel removal
Old Jan 1, 2009 | 11:03 AM
roofer's Avatar
roofer
Default Rear wheel removal
The manual say's you have to drop the swing arm to remove the rear wheel, is that to clear the fender anyone got an answer, its no big deal to drop the swing arm it just seems odd I'm used to softails Thanks
Old Jan 1, 2009 | 11:17 AM
JayFromPa's Avatar
JayFromPa
All you have to do is jack the bike up high enough for the swingarm to drop down far enough for the tire to clear the fender.
Old Jan 1, 2009 | 11:21 AM
jmpancoast's Avatar
jmpancoast
Lower the swingarm by dropping the shocks. This allows you to remove the drive belt without having to move the axle adjusters. It will also make it easier to replace spacers when you reinstall the wheel because you can hand lift the swingarm out of the way.
Old Jan 1, 2009 | 11:24 AM
fixxr's Avatar
fixxr
+1 as Jay said and you might want to remove the upper belt gaurd,it makes it a lot EZ'r and you will not scatch your rear pully.
dustin1014
Nov 23, 2012 06:34 PM
j jacks
Jan 13, 2012 05:49 PM
Route66rider
May 31, 2010 03:15 PM
gplarryv
Apr 2, 2009 09:17 AM
WarriorHD
Mar 16, 2007 08:13 PM
