tach for FXD35?
Old Apr 16, 2006 | 02:44 PM
oregonrider's Avatar
oregonrider
Default tach for FXD35?
I'm thinking about a tach on my FXD35. Any other '35 owners out there that have added one? I guess it wuold mount on the handlebar mount. I'd like to see a pix of one before I buy. oregonrider
Old Apr 16, 2006 | 11:18 PM
superdog48's Avatar
superdog48
Default RE: tach for FXD35?
I have seen one at the local HD shop, it was not on a 35 but on a FXDWG, and it looked goood to me. But that is my opinion.
Old Apr 17, 2006 | 12:52 AM
bobcowan's Avatar
bobcowan
Now a whole lot of choices in that size. I've not seen the dual gauge in that size yet. If I ever do, I'll seriosuly consider it.
However, my '97 WG went through 3 speedometers in 45K miles. If they were the dual gauge type, it would have been a lot more expensive.
But, I have seen pictures of this gauge set up. Alloy Art A little expensive, but very nice. This is my current favorite option. I've seen it installed, and it really looks nice.
Old Apr 17, 2006 | 06:29 AM
cardin4l's Avatar
cardin4l
6th Gear
Instead of buying a tacho use the speedo??
Does anyone have the gearing graphs for FXD's? i.e. what speed = rpm ?
Old Apr 17, 2006 | 08:55 AM
fl_799's Avatar
fl_799
The cleanest install will certainly be the Speedo/Tach combo that Harley makes. Discounts from an online vendor, the price is not too bad. We have consoles on the 35's, might as well use whats there.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Apr 17, 2006 | 11:36 AM
ItsaHarley's Avatar
ItsaHarley
I just wish they had them in the same white face and font as the OEM speedo.
Old Apr 17, 2006 | 12:24 PM
johnpiech's Avatar
johnpiech
I like the tach/speedo combo too - but it is around $450.
Old Apr 17, 2006 | 05:00 PM
dyna2319's Avatar
dyna2319
I just put a tach on my WG and you can get in the same style as the speedo, but I mounted mine on the bars makes it easier to look at the road and the tach at the same time. The cost was about $200. for the setup I think. HD makes you buy everthing separate, tach, housing, monting bracket. You will need to do some wiring for the three leads though. Not sure on your specific install, but is doable if you have some mechanicjal abiliity and can read and follow the directions for your model.
Phil
06 FXDWI
Old Apr 17, 2006 | 06:11 PM
fl_799's Avatar
fl_799
You missed the part about online discount. Chicago HD they are $359.96
ORIGINAL: johnpiech
Old Apr 18, 2006 | 01:44 AM
bobcowan's Avatar
bobcowan
ORIGINAL: fl_799
Those are really nice. A little expensive, but not too bad. But they won't fit the FXD35, Superglide, or Bobber. The speedo on those bikes are smaller than the WG.
gartec81
Aug 1, 2015 08:26 AM
murrayliving
Mar 26, 2014 06:10 PM
rauchman
Oct 29, 2013 09:01 PM
sanlyn
Mar 6, 2010 06:52 PM
Boxjoint
Nov 29, 2006 05:57 PM
