FXDBI Front end clunk
Old Apr 19, 2006 | 12:49 PM
dakotacrk's Avatar
dakotacrk
Default FXDBI Front end clunk
I saw the thread on this issue and the same thing appeared on my bike sometimes. If it is a Headset problem it would do it all the time, everytime you applied the front brake, hit a bump. Mine did it sporadically.
I had a friend sit on the bike, hold the front brake and rock the bike back and forth, only to hear the same thing. I looked and felt for movement at the the head bearings adj/nut, nothing. I followed the sound to the front fork some noise, then I notice that the front brakespads moved with the noise. Bingo. HD new floating brake system, that explains why they only do it sometime.
Now how do I stop the squealing of the rear brake?
Old Apr 19, 2006 | 02:41 PM
bobcowan's Avatar
bobcowan
Default RE: FXDBI Front end clunk
Brake squeal is usually caused by the pads vibrating in the caliper. Take out the pads and clean the back of the pads and the contact point in the caliper. Apply a little bit of Permatex Disc Brake Anti-Squeal. It's like glue. Let it sit overnight and you're done.
Old Apr 20, 2006 | 10:59 AM
95BadBoy's Avatar
95BadBoy
pads could be glazed. remove and rough up surface with sand paper.
also bevel leading edge slightly.
Old Apr 20, 2006 | 05:08 PM
Oilslick's Avatar
Oilslick
I was begining to think I was the only one who put this clunk down to the floating rotor.
John CC
Aug 26, 2019 03:46 PM
SunRa73
Sep 27, 2008 10:46 PM
69Shark
Feb 25, 2007 09:45 AM
SPECIAL ED
Aug 12, 2006 08:18 PM
SubZer0
May 19, 2006 11:56 PM
