True Track Test Ride-OOPS!
I guess I forgot to tighten the travel limit bolt on the front stabilizer. Ahem, like the instructions say to do.
The bolt backed out, seemed to lock the motor from travel, and then the vibrations increased a lot. Tried to turn it in by hand, but no luck.
Rode home, about 10 miles, easy.
Vibrated my left front signal off. Checking everything.
Other than that, I gotta say the thing works.
Makes my bike feel like the front and rear are better connected. Does that make sense?
People I've spoken to have it adjusted like yours. Does it do anything except cause problems if not locked into place?
Mine's a bagger but the True Track straightened my $hit out!
I don't see that it is much of an issue. I think True Track is the only manufacturer that has the limit stop. If the motor moves enough to need that stop, you probably need to replace the rubber mount.
The system works. Enjoy the solid ride!
