Kickstand danger
Old Feb 18, 2009 | 07:54 AM
downsmith's Avatar
downsmith
Default Kickstand danger
My friend has a WG that after he lowered it and put a wide rear tire tire on it, the kickstand is dangerously close to the ground. He also has to lean it to the right in order to swing it down.
He was asking if you guys had any fixes for this.
Old Feb 18, 2009 | 08:04 AM
thedonthere's Avatar
thedonthere
I just did a kick stand mod. Do a search. There is a tab on the stand underneath. This tab makes contact with the frame. If you grind off 5mm from this tab it will lower your stand about 1" on the end. If you remove too much material it will not work. 5mm worked for me.
Old Feb 18, 2009 | 08:55 AM
JRK5892's Avatar
JRK5892
you can also just heat and bend it out... both work
Old Feb 18, 2009 | 08:58 AM
FUQUA's Avatar
FUQUA
I need to do that mod myself after lowering the front, the bike sits about straight up, everywhere i go i stare out the window checking it.
Old Feb 18, 2009 | 09:05 AM
FUQUA's Avatar
FUQUA
Can someone find the thread about the kickstand mod?And post the link. I did a search and cant find it....it would be greatly appreciated.
Old Feb 18, 2009 | 10:16 AM
NoLongerAmember's Avatar
NoLongerAmember
There is this one I saw
https://www.hdforums.com/forum/3258533-post818.html
CB
Old Feb 18, 2009 | 10:24 AM
FUQUA's Avatar
FUQUA
Originally Posted by cbz1200n
Thats the one thank you!!
Old Feb 18, 2009 | 10:32 AM
thedonthere
Hey FUQUA that kickstand mod works well. 5mm is enough. Don't take too much material off.
Old Feb 18, 2009 | 11:01 AM
Cornhusker's Avatar
Cornhusker
I just heated and bent mine a week or so ago. Works great except it is now hard to find with your heel when you wanna put the stand down. I hate to have to put one of them damn extensions on it.
Old Feb 18, 2009 | 01:04 PM
CRF's Avatar
CRF
Hey Fuqua - love your bike - how much have you lowered the back and the front? are those struts on the back?
