replacement motor mounts
Old Dec 16, 2017 | 03:44 PM
  #51
cggorman's Avatar
cggorman
Originally Posted by Renegade946
I need help. I just replaced my front and rear motor mounts and when I finished, I took it off of the jack and was going to test ride it and I have no power when I turn the ignition on. Prior to replacing the motor mounts, I had power. Any and all suggestions would be appreciated.
I don't remember any power running around the rear mount, but you may have jostled the voltage regulator wiring up front.
Old Dec 16, 2017 | 09:45 PM
  #52
Renegade946's Avatar
Renegade946
6th Gear
I checked the voltage regulator wiring and it is connected to the stator, but I did not check to see if maybe I pulled the wire loose from the 30 amp main breaker. I will check it on Sunday. Thank you.
blackflame
Jan 6, 2021 03:11 PM
Big Dave
EVO
May 5, 2015 06:37 PM
murrayliving
Dec 21, 2013 06:39 PM
bigtexme
General Topics/Tech Tips
Oct 15, 2012 06:40 PM
nujohn
Mar 15, 2008 03:43 PM
