running 05 pipes on an 08
Old Mar 13, 2009 | 12:52 AM
donr101395's Avatar
donr101395
Question Is it possible to run 05 pipes on an 08
I'm sure it's been asked, but my searchfu is weak tonight. Is there any reason you can't run a set of 05 and earlier Bassani pro street pipes on an 08 with a PCIII and O2 eliminators? I can't think of a reason it won't work, but I'm wondering if I'm missing something? I'm also seeing a lot of good deals on pre-06 pipes.
Thanks,
Don
Old Mar 13, 2009 | 12:55 AM
devils haircut's Avatar
devils haircut
Thanks,
Don
You can! You will just have to do a little fab work to the bracket, I think.
Old Mar 13, 2009 | 09:06 PM
donr101395's Avatar
donr101395
That's what I was thinking too.
Old Mar 13, 2009 | 10:41 PM
bennydog's Avatar
bennydog
Yes I have a thunderheader form an 02 on my 08 had to grind a little on the bracket but with the pcIII and the o2 eliminators It works just fine
Old Mar 13, 2009 | 10:43 PM
OutlawBagger's Avatar
OutlawBagger
I got 05 Hooker troublemakers on my 09 and a PC V. Had to trim the bracket a little but they fit and work.
Old Mar 13, 2009 | 11:02 PM
donr101395's Avatar
donr101395
Thanks guys, I found some stainless Bassani Pro Streets I can get for around $260-$280 delivered I think I'm going to grab.
Old Mar 13, 2009 | 11:18 PM
ackman1968's Avatar
ackman1968
One potential problem, the oil filler location is different on 05 and older bikes. The pipes may come down right where the fill tube is on the 06 and later. They don't give a good enough side shot of them to be able to tell. The only reason I brought this up is I had a Vance & Hines pro pipe for an earlier bike I could not use. Had I put it on I would not have been able to get to the dipstick to check the oil.
Old Mar 13, 2009 | 11:27 PM
donr101395's Avatar
donr101395
I thought about that, but from comparing the pics, it looks like checking the oil could be a PITA with either set on an 06-09.
06-09
05
Old Mar 17, 2009 | 10:40 PM
donr101395's Avatar
donr101395
I'll let you guys know how it works out. I just bought a set of Bassani Pro Street stainless pipes for 91-05 NIB for $271.00 delivered. They should be here Monday or Tuesday. I'm planning on wrapping the header back to the muffler in black. The Legend Billet FWD controls should be here about the same time, so I know what next Friday night will consist of.
cmonster
Aug 31, 2009 05:13 PM
AdrianVall
Oct 12, 2008 10:24 AM
RockyTopRider
May 26, 2008 09:21 AM
Rastus
Exhaust System Topics
Nov 18, 2007 04:20 PM
speed8988
Feb 11, 2007 10:29 PM
