Does this indicate a rich condition?
Old Mar 16, 2009 | 08:49 PM
YellowHawk's Avatar
YellowHawk
Thanks to everyone that replied. I checked them because it was running like crap after the water in the PCIII connectors. I'll get a new set installed and run it awhile and check it out.
Old Mar 16, 2009 | 09:19 PM
madden23's Avatar
madden23
OK, forget the plugs a minute, since the pictures look like totally different plugs, wipe your finger on the inside of the exhaust pipes, are they full of soot?
Old Mar 16, 2009 | 10:28 PM
dlstanf2's Avatar
dlstanf2
I installed a PCIII without having my ride tuned. And, I had popping, shooting BLUE flames out, pipes were black, and the plugs were black and sooty. Thought I was running way RICH. Not so. Finally had my bike dyno tuned and found out that I was way too LEAN, Now my bike runs well. I had been using the SE plugs, but the Indy told me he preferred the standard HD plug; for some reason he had better luck with those.
BTW, I picked up around 8HP & 8 lb ft of torque.
And, with a dyno tune, you have both cylinders set to their optimum.
Old Mar 17, 2009 | 04:57 AM
YellowHawk's Avatar
YellowHawk
Madden23 I'll check the pipes. They do look black on the inside but they have since I installed them. I've only had the PCIII on for a couple of weeks.
Dlstanf2, that's what I'm worried about. I want to make sure I'm not running too lean.
Old Mar 17, 2009 | 05:21 AM
RangeRat's Avatar
RangeRat
THIS is your best approach YH. Some new properly gapped plugs and run a tank through her. No excessive pinging or popping? If not, then that's cool. Finally, use that link EDZ82FXR provided and check the plugs for sure.
Old Mar 17, 2009 | 09:10 AM
JRK5892's Avatar
JRK5892
i dont think it looks bad... not sure why the 2nd pic is so dark but the first one look about where you want to be
Old Mar 17, 2009 | 12:46 PM
dlstanf2's Avatar
dlstanf2
YellowHawk, if you are too lean, you can fry a piston. I've seen it happened. Running a little rich will help keep your oil temp down as well.
cajun1957a
Feb 27, 2017 07:55 AM
Captain Itch
Jan 29, 2008 10:44 AM
BigJfxdwg
Jun 1, 2007 12:25 PM
dognut
Apr 18, 2007 11:08 AM
Naz_Man
Feb 13, 2006 02:18 AM
