BCT Baffles
When I had them on my SEII's though, they actually created a minor dip (3-4 lbs) in the torque curve at about 3,000 rpm, but increased total HP (@ 6,000) by 3-4 HP.
Has anyone played around with them and run the baffles in the original mount holes and then moved them deeper into the pipe?
I'm really curious of the sound difference.
Anyone?
Btw, brown just delivered the V&H BR to my door.
1) My pipes only have 100 +/- miles on them. Will this make it easier to remove the stock baffles? I hear a lot of people have trouble with the top baffle.
2) Removing the heat shields (dealer installed), do you just have to loosen the clamps and slide heat shields off, or is there something more? I loosened them this morning and the shields slid an inch or so, but then wouldn't slide any more. I didn't tug too hard in case there was something i was missing. Do you have to remove the clamps entirely?
3) As far as placing the BCT baffles, are you guys just placing them at the end of the pipe (not the 6" that BCT recommends)? Or if you are setting further back, are you plugging the hole from the stock baffles? I read on one post here a guy said you actually have to go 6 1/2 inches back to miss the heat shield clamp.
Overall, it sounds like this isn't the hardest thing to do, but then again, i'm far from being a wrench.
Thanks!
Thanks!
Thanks!
I placed my baffles 6" in and ran the clamp over the bolt, Almost as good as loctite
Thanks!
I do not think the pipes being new will help much on getting the baffle out. There are a few tips that were posted on here but I wouldn't bother removing the pipes and putting them in a freezer or anything that time consuming. Joe's idea was great, he just drilled a small hole and I think screwed in a small screw and then got it out with a slide hammer? (I think) and another guy posted how to yank it out with a socket on a small cable, all kinds of great ideas and it's not THAT tight, just tight enough you can't do it by hand.
On the heat shields, the clamps toward the exit end of the pipe, loosen those generously. The clamps toward the front of the pipes, completely separate those, you have to pull them all the way apart since the clamp cannot slide past the brackets. Pull the front half straight off the side and slide the rear half off.
On placement, who knows, maybe I am missing out on some performance but I put mine right in the stock location and they are great. Don't let placement stop you from getting them. If nothing else just use stock location like I did and worry about where to put them later.
You can have them installed in less than 20 minutes too, guaranteed.
Hope they are as good as everyone is saying
I'm planning on installing these this weekend but wanted some input on performance.
Thanks
