On my '09 FXDB, I am curious if it is normal that every time I hit a medium to large bump in the road, the rear suspension feels like a hardtail. It literally bumps me temporarily out of my seat. Makes me kinda nervous, especially on turns on the highways. Is this just the way the bike is, or if I loosen the suspension up a bit to the lowest setting, or lower setting using a spanner wrench, will it make a difference. I weigh 160 lbs, anyone have similar problems or input on hopw I should adjust the rear to suit my weight better?
gain more weight, harder to bump you out of the seat sorry, had to say it... I am 240 and don't have that problem, but sure someone will provide answers that aren't as smart as mine...
You can just look underneath also to see which way to turn. I'm 220 and have mine on the second setting. I rode the first month I had the bike on the lowest setting and was fine. I might actually go back to the first setting, but I need a spanner wrench. I used the dealers last time. There's no need to have it on the highest setting unless you are riding two with gear or weigh more then 160!
In my personal experience, the Dyna has the absolute worst rear shocks I have ever seen (I currently have 10 bikes). I weigh 200, same experience you describe.
I purchased some new Ohlin shocks, rather expensove, but totally transformed the ride. Any aftermarket shock is likely better than what you have. Get the same (or longer) length. Shorter will just make it worse, if thats possible
Forks out of a box, whether it's Harleys or aftermarket will not work, unless they are sprung to your weight, because you are lighter than normal, at the least amount of preload, those stock shocks are still probably too stiff for your weight. Too stiff= uncomfortable and loss of traction.
