16inch apes
Old Apr 7, 2009 | 03:31 PM
BigJfxdwg's Avatar
BigJfxdwg
Default 16inch apes
Just wondering if I need new cables and wiring to go to 16 inch apes on a 05 WG or if the stock cables and wires have enough slack? I was going to leave the stock mini apes until I have been messing around with a buddy's Street bob with 16's and they fit me perfect so now I'm doing some investigating.
Old Apr 7, 2009 | 03:43 PM
JRK5892's Avatar
JRK5892
yes... i was able to do 16.5 total rise on my bobs stock cables but it took alot of re routing and bending of brake lines... you are going to have to replace them on the WG though not enough there
Old Apr 7, 2009 | 03:45 PM
BigJfxdwg's Avatar
BigJfxdwg
That's what I figured, the brake looks like it may be tight. Clutch looks like some play along with the wiring harness but it's hard to tell without really digging in at this point.
Old Apr 7, 2009 | 05:27 PM
BigJfxdwg's Avatar
BigJfxdwg
Anyone know about the clutch and wiring or am I going to have to dig into it and be suprised?
Old Apr 7, 2009 | 07:06 PM
Kaycee's Avatar
Kaycee
I been looking at this setup allso, I have got the stock apes on with 4 1/2" risers so I'm sitting at 14" and have just enough idle/throttle cable,had to tweak the brake line and the clutch is still good.I think the wiring would be good on the 16" but I belive the clutch would need to be extended along with the brake,idle/throttle cables.
Old Apr 7, 2009 | 07:18 PM
RKLeo's Avatar
RKLeo
My 05 required a little extra wire harness with only 14" apes. Another member said he was able to stretch his wires to 16" apes on the same model. I guess some are different. The cables I was replacing anyway. I just ordered extended length out of the gate. I never tried to see if the stock cables would work.
Old Apr 7, 2009 | 07:31 PM
BB_Stackr_86's Avatar
BB_Stackr_86
6th Gear
Default Gotta go longer (wires that is)
I'm smack in the middle of this project, my 04 Wide Glide was totally stock. I'm doing 16" Wild 1 apes with fat stock height risers. Went 8" over on throttle/idle & clutch cables, and a 50" universal brake cable.
I'm just doing the wiring now, the stock wires are long enough to do the bars but it looks like I'll need 6-8 inches of extension for both to go into the frame.
Hope this helps!
Joe
Last edited by BB_Stackr_86; Apr 8, 2009 at 06:35 AM. Reason: changed wiring length
Old Apr 7, 2009 | 07:46 PM
BB_Stackr_86
6th Gear
duplicate post
HWill
Mar 31, 2017 05:37 PM
ajmilberg
Nov 26, 2012 04:19 PM
EzStreet
Aug 11, 2009 08:35 PM
fryddog
Jan 29, 2009 06:30 PM
phog light
Jan 18, 2009 06:04 PM
