exhaust bracket removal?
Old Apr 21, 2009 | 04:51 PM
dynabagger's Avatar
dynabagger
Default exhaust bracket removal?
This might be a dumb question, I had my pipes put on at the local stealer. When I got the bike back this bracket for the stock pipes was still there. I don't know if oil will leak out if I remove it. I have seen several other dyna's that this bracket was still on also. I don't see anything about this in my service manual. Can I take it off?exhaust bracket removal?-bracket.jpg
Old Apr 21, 2009 | 04:59 PM
JRK5892's Avatar
JRK5892
honestly... i left mine on... i had already powder coated it black... and now i use it to lock my helmet... works great!
Old Apr 21, 2009 | 05:11 PM
Shrug's Avatar
Shrug
I tried seven ways to Sunday to take mine off. Some here have fabricated a tool using a chopped torx bit welded to a wrench-like piece of metal to take theirs off. I have no such resources, but would pay for one if it were available and just pass it on to the next guy who needs it.
Old Apr 21, 2009 | 06:06 PM
painguy's Avatar
painguy
I have the same problem. I saw a post on here about a month ago where a guy put up a picture of a dyna exhaust bracket removal tool from jp cycles for 24.99. I looked in my catalog and didn't see one. I have tried to get it off but don't want to strip out the holes until I find the right tool. I really don't want to spend 25.00 to take off the bracket.
Old Apr 21, 2009 | 06:22 PM
sata6's Avatar
sata6
i took mine off with a cut down torx bit t-27 it took alot of patiance but i got it off.
Old Apr 21, 2009 | 06:40 PM
phatman's Avatar
phatman
Default Found it
J&P does have a tool. Seems kind of expensive though. here's a link for those interested. http://www.jpcycles.com/Search/Produ...results=10&No=
Old Apr 21, 2009 | 07:03 PM
dynabagger's Avatar
dynabagger
Default Success
I got that ugly a@# bracket off! Made my own tool. Took the torx bit out of a torx socket, it has a little tit on the bit to hold it in the socket. Drove the bit into the closed end of a 1/4 inch wrench, little tit held it in the wrench. Got that on the bolt, then put the closed end of a 9/16 wrench on the 1/4 wrench. Wrapped a piece of gasket material around the frame (no scratches) then used a screwdriver to push up on the bit. Took some force but got the bolt broken then took a wobble torx bit and got it the rest of the way out. Only had to do this on the outside bolt at the front of the bracket. Used a torx screwdriver with a pair of pliers to break the other to bolts loose.exhaust bracket removal?-bike-2.jpg
Old Apr 21, 2009 | 07:06 PM
bberck's Avatar
bberck
My D&D reused the stock bracket.
Old Apr 22, 2009 | 03:54 AM
jimw411's Avatar
jimw411
I was able to reuse the stock brackett that goes around the pipe and bolts to the brackett when i did the Big Shots staggard on my 06'. When i put the short shots on my wifes 07' It wouldn't line up bacuase the pipes are bent different and are a little further away from the motor.
Old Nov 27, 2015 | 04:51 PM
jasunto's Avatar
jasunto
having the same struggle and found this thread, i have V&H pro pipe and noticed this damn bracket, frame has it blocked from almost all access. I got a 1/4" bit ratchet which got one out/loose, one stripped, the other i have no access. Im about to get a torx bit and hack saw it down with enough nub to fit a 1/4' box end wrench over it. Damn stealership would charge $100 to remove during oil change im sure. I would like to put them stock torx bolts back in the holes afterward.
