Time for new valves?
Old May 11, 2009 | 06:44 AM
Failz's Avatar
Failz
Default Time for new valves?
Okee dokee. My valves look white and powdery which makes me think time to put some new ones in. 1. I have never done anything like this before (I have the service manual but tips would be greatly appreciated.) 2. Do I need to change my valves? 3. What would cause the white build up? Also see the sheared bolt? Any good methods to removing these?
-Thanks
Old May 11, 2009 | 08:00 AM
r00k's Avatar
r00k
For the broken stud, https://www.hdforums.com/forum/dyna-...-stud-f-k.html
For the valves: https://www.hdforums.com/forum/engin...lve-color.html
Old May 11, 2009 | 08:41 AM
archergodwin's Avatar
archergodwin
I would go ahead and remove the heads and at a minimum get the valves cleaned up and reground, new would probably not be a bad idea just from the age of the bike. Get the heads cleaned up while you're at it. Head being off would make getting at the broken stud a little easier.
Looks like you had a pretty severe exhaust leak for quite a while on the head in that picture.
Old May 11, 2009 | 01:51 PM
arkieollie's Avatar
arkieollie
Just out of curiosity...how many miles on that motor?
Old May 11, 2009 | 02:06 PM
mehurr's Avatar
mehurr
maybe time for some SE heads? Nothing like making a problem an upgrade!
Old May 11, 2009 | 02:21 PM
jstreet0204's Avatar
jstreet0204
That's my way of thinking right there!!! A problem is either a reason to upgrade or a reason to buy some new tools
Old May 11, 2009 | 02:58 PM
Black Bart's Avatar
Black Bart
+1
Bart
Old May 11, 2009 | 09:10 PM
mgibson61611's Avatar
mgibson61611
What do the plugs look like? (is it jetted properly, or way lean...)
Old May 11, 2009 | 09:55 PM
dope_man_21's Avatar
dope_man_21
To me it looks as if it was running lean or with an exhaust leak. If I were going through this and money was not a concern I would upgrade the heads, if money is tight, replace the valves and have the valve seats reground. Regaurdless to which you decide to do, the first thing to do is to determine the root cause of your problem or it will just come back to get you again.
Jollyczar
Shovelhead
20
Jul 7, 2019 06:49 AM
cory464
Feb 7, 2018 10:45 AM
fastmofo01
EVO
19
Jun 24, 2013 08:54 PM
VA_Grumpy_Biker
Jan 26, 2011 06:38 AM
Spitshine
Shovelhead
Feb 10, 2008 09:18 AM
