06 Dyna changing tank
Old Jun 5, 2009 | 08:48 PM
misterrick's Avatar
misterrick
Default 06 Dyna changing tank
I have a silver 06 dyna fxdi with a dent in the tank. I was just wondering what it would take to put a wide glide or other tank on. I kinda like the speedo on the tank and the bigger tank look. I figure most of the wiring would be the same but you never know thought I'd ask you guys.
Old Jun 6, 2009 | 02:49 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
the dynas have used 3 tanks since 2004.
tank#1 = 04+ Superglide, 04+ FXDX, 04-06 superglide custom (FXDC), 07 FXDSE
tank#2 = 04+ Lowrider, 06+ Street Bob, 08 FXDSE.
tank#3 = 04+ wide glide, 06 35th anniversary, 07+ Superglide custom, 08+ Fat Bob
You'll have speedo/indicator light wiring to contend with, as well as ignition wiring relocation. It's doable, but I haven't had any direct experience. I don't think HD would have different wiring harnesses for the different Dynas; maybe just routed and/or tied different ways.
Old Jun 6, 2009 | 04:27 AM
super05's Avatar
super05
you need a new speedo, new dash, new ignition switch,new lamp cluster, new fuel gauge and filler cap, new tank top plate and gasket. The speedo harness will plug right in - but you'll need to either get all of the connector pieces for the lamp side, or cut and splice. most of these parts - with the exception of the tank itself rarely show up on ebay. if you get a good tank for - lets say $300, you need to realize that you're still over $500 away from making it work.
tayls87
May 25, 2013 04:39 PM
rooti
Apr 15, 2012 10:34 AM
moonsfmc
Aug 26, 2008 10:30 PM
glide05
Jul 10, 2008 09:38 AM
songsmith
Mar 26, 2008 09:45 PM
