Tri bar install.
Old Jun 6, 2009 | 08:30 PM
MYKSHD's Avatar
MYKSHD
Default Tri bar install.
Can I just take the bottom shock bolts out and with the bike on a jack drop the rear wheel enough to access the tie straps that need to be cut.Thanks Mike.
Old Jun 6, 2009 | 08:51 PM
ColdCase's Avatar
ColdCase
I pulled the extra inch or so wire length I needed without cutting any straps inside the fender, just the one under the seat. The tail light assembly that needs to be replaced is bolted to the fender. The bolts are behind the fender support cover.
wingman1800
Apr 9, 2014 10:20 AM
THUND3RHOR5E
Mar 10, 2014 11:13 AM
03_Nightrain
Feb 28, 2013 12:40 PM
SoCalSoftailSlim
Feb 13, 2013 11:09 PM
sgdiesel
May 18, 2009 08:34 AM
