Stiffen up forks?
Old Jun 16, 2009 | 12:24 PM
MNrider's Avatar
MNrider
Default Stiffen up forks?
What's the easiest way to stiffen up my forks?
Old Jun 16, 2009 | 12:28 PM
dwg1956's Avatar
dwg1956
On my 03 Wide Glide I drained the stock fork oil out and put in Screaming Eagle Heavy fork oil. Stiffened it up quiet a bit but not too stiff. I really like the feel.
Old Jun 16, 2009 | 12:29 PM
paul s's Avatar
paul s
Changing the springs and oil is easy.
Old Jun 16, 2009 | 12:30 PM
bberck's Avatar
bberck
A fluid change can stiffen it up but if going to do that I would go ahead and put new springs in as well. You can get springs for under $100.
Old Jun 16, 2009 | 01:16 PM
MNrider's Avatar
MNrider
Do i need to put it up on a jack to do this stuff? Or will the jiffy stand work?
Old Jun 16, 2009 | 01:24 PM
bberck's Avatar
bberck
You need the front wheel off the ground. I built a homemade little lift out of scrape wood I had in the garage when I did mine.
Its not the prettiest thing but it works great.
Old Jun 16, 2009 | 01:34 PM
paul s's Avatar
paul s
The heavy oil and springs are said to be stiff by a few people on this site, I went with 10wt/medium oil and springs and all is well, I guess it all depends on your weight and riding habits.
Old Jun 16, 2009 | 01:38 PM
mccalljv's Avatar
mccalljv
+1, I put in the SE oil when changing the lowers and so far I like the feel. Next time I will probably go to progressive springs...
Old Jun 16, 2009 | 01:57 PM
thedonthere's Avatar
thedonthere
I did both SE oil and Progressive springs and the diffrence was incredible. Factory HD suspension is really **** IMO. This winter I will do a serious suspension upgrade.
Old Jun 16, 2009 | 02:26 PM
JRK5892's Avatar
JRK5892
i got a progressive lowring springs, with a 50/50 blend of 15w and 10w fork oil... it is AWESOME! not too stiff not too loose, just right!
