Windshield angle change
Old Jan 18, 2010 | 05:26 PM
JaronB's Avatar
JaronB
I thought about somehow bending the bottom of the shield out a little because I notice all my buffeting is coming up my shins. When I ride I put my arm across my knees and it all went away even wind noise. I thought about using a torch and bending, but I'm afraid of ruining it. So I may just get longer bolts and washers at the lower bolt on the support brackets. I noticed with the shield it diverts a lot of wind to the shins and there is no way I'm putting lowers on there.
Old Jan 30, 2010 | 10:16 AM
reesestewww's Avatar
reesestewww
Originally Posted by Kanzig
I am bringing this thread back to life just for an update on changing the angle of these Quick Detach windshields. I found at the hardware store something that works better than the S-hook and is more rigid. It's called a mending plate, I picked them up from Ace Hardware in a package of 4. The holes needed to be widened with a 1/4 drill bit but once that was done, the concept was exactly the same. I'll post pics soon but here is a link to the mending plate:
http://www.acehardwareoutlet.com/(e4...?sku=998082125
Like it shows, it's just a piece of flat steel that is about 2 inches long with a hole at each end. Use this in place of the S-hook above. This actually increases the angle even more than the S-hook did.
Kanzig
I'm line buying these now. They didn't have 5/8 so got 1/2. Should be ok. I'll let ya know how it goes!
Old Jan 30, 2010 | 10:32 AM
Kanzig's Avatar
Kanzig
Excellent. My only regret is they dont make those in stainless steel or chrome darnit. In your case you could just sand them with 800 grit and then paint and bake with the BBQ black paint.
JCAPPS29
Jul 27, 2016 06:36 AM
BikerDude13
Apr 20, 2012 09:00 PM
hyak107
Oct 20, 2008 08:28 PM
DPete
Sep 28, 2007 01:45 AM
mchacon
May 16, 2006 03:46 PM
