rear blinker removal?
Old May 23, 2006 | 10:02 AM
jkenosh's Avatar
jkenosh
Default rear blinker removal?
Does anyone know how the wires pull out of the connectors on the rear blinkers?
Old May 23, 2006 | 12:04 PM
StBobBobby's Avatar
StBobBobby
Default RE: rear blinker removal?
I have an 06 SB Dyna and I have to put the blinker extention kit on mine to put on the removable sissybar. The wires don't come out of the blinker itself, they are soldered into the light bulb housing. What you have to do is unplug it from the tail light and pull it out of the fender. You may still have to cut the wire if you want to remove the blinker standoff.
Old May 23, 2006 | 12:44 PM
gbm's Avatar
gbm
No point in cutting wires. Unplug the connector from the board in the tail light and look at it closely. The wire end is held in place by a plastic tab that can be lifted with a small jeweler's screwdriver or similar (flat tip is the key) inserted in the female end of the connector and on top of the wire. It's visible from the slotted top of the connector if you look close. It can be a PITA because it takes three hands to make it easy. It's all in the service manual with good pictures if you can look at one.
Old May 24, 2006 | 01:10 PM
jkenosh's Avatar
jkenosh
i figured out how to un-plug the wires, you need a strong paper clip, once you figue it out its easy
Old May 24, 2006 | 05:44 PM
StBobBobby's Avatar
StBobBobby
I wish I could have done it. I tried to do it but couldn't figure out how to get those guys out.
vickon
Oct 12, 2022 08:49 AM
88racing
Aug 28, 2009 01:17 PM
ncbeast
May 16, 2009 08:17 PM
Biggzed
Jan 21, 2008 07:35 PM
ChromeJunkie
May 8, 2007 09:19 AM
