Problem with my ape hangers!!!
Old Jul 22, 2009 | 10:44 PM
Pendragon's Avatar
Pendragon
Unhappy Problem with my ape hangers!!!
I installed a 16" Carlini chino ape handlebar last september and have been riding it all over the place until recently when i tried to pull it off the trailer as it came back from the dealer and the bar gave way....
I checked the bolts and they were all properly tightened but it is still loose... Has anybody had any similar trouble with ape hangers and what can I do to solve this problem?
Thanks...
Old Jul 22, 2009 | 10:50 PM
MyBeerBelly's Avatar
MyBeerBelly
check your risers and make sure the bolts are not cross threaded....if not loctite them and tox them up....ive had my carlinis on for about 4 month with no probs and i ride it a ton
cheers
J
Old Jul 22, 2009 | 11:32 PM
RKKY's Avatar
RKKY
Would recommend the polyurethane bushings from H-D whenever you change bars, especially for apes. They will usually get rid of most of the h-bar slop. I'm putting 16" apes on my FXD as soon as my new front end arrives and will be swapping the bushings out. Hell I'm switching my FLHX bars out on Monday to the same size as currently on there (but in black) and I'll be switching out the riser bushings on that one too.
Old Jul 22, 2009 | 11:39 PM
Yellotang's Avatar
Yellotang
If you are talking about the handlebars moving loosely separate the risers then either a rubber pad between bars and rised crimped will stop that. I have also seen crushed beercans do the same.
Old Jul 23, 2009 | 06:47 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Put a thin piece of rubber (bicycle tube) between the bars and riser. Then Loctite and torque the bolts.
Old Jul 23, 2009 | 06:57 AM
SC-Longhair's Avatar
SC-Longhair
Why 'poly bushings from hd"? I got mine from HCCC on ebay for 9.95. I just checked the price from HD...$39.95. WHY!?!?!
Old Jul 23, 2009 | 07:24 AM
mplecha's Avatar
mplecha
I've had my apes on for over a year. they haven't moved at all since I installed them.
Old Jul 23, 2009 | 07:46 AM
jsbridgew's Avatar
jsbridgew
The stock riser on Harley's are the worst. They just don't grip properly on aftermarket bars. I had my Wilds slip a few times even though i tightened the riser bolts a tad beyond torque spec. I got rid of them and bought a Burly one. Now, I have to virtually loosen the thing completely for the bars to move. They bite into the bars, nicely!
Old Jul 23, 2009 | 08:07 AM
Airborne350G's Avatar
Airborne350G
Ditto on that...
Old Jul 23, 2009 | 08:39 AM
SC-Longhair
The stock 1.25" diameter risers are fine. They held my stock 1.25" mini-apes without a problem but then I went to 16's that stepped down to 1" at risers. I bought a 1" to 1.25" adapter from wild1 and I could never get the clamps tight enough. The adapter was knurled on the outside but not on the inside where it would contact the bars so there was no 'bite'. I probably could have dimpled the bars and been fine. When i replaced my 16's I installed a true 1" diameter riser and those bars don't budge an inch. As far as the bushings, they're rubber to isolate the vibes but you compromise rigidity. I added poly bushings during this swap recently and the bars have no play in them at all. I do feel slightly more vibes through the grips now though. Again, another compromise.
