Gimp Hangers
Old May 26, 2006 | 06:59 PM
SDMF's Avatar
SDMF
Default Gimp Hangers
Okay guy's...I've got my 14" Gimp Hangers on the way for the Bob, and want to ask anyone out there who's changed their bars if I need to do anything special when taking the switches off the old bars. For example: springs or other internal parts that will go flying out if you take the housing completely apart??? Or is is best to crack the bolts loose and just slide them off??? Also, because I'm going to keep my wiring on the outside of the bars, will there be enough length for the extra 2" or do I need to buy new cables??? It looks like the way they're wraped under the stock risers that if I run them from the front side I may have enough length.
Thanks for any insight...I'm stoked about the this mod and can't wait to git-r-done and post some pics. [sm=partyparty.gif]
Old May 26, 2006 | 07:52 PM
phreak's Avatar
phreak
Default RE: Gimp Hangers
I didn't put Gimps on, buy I did go to 14s. Electrical wiring should be long enough, especially if your going on the outside. There is more wiring then what you see stuffed into the phrame. Pull a little extra out.
There shouldn't be anything phlying out of the switch housings. But be careful, there is a "shoe" on the throttle side that the tension nut screws into. If you loosen the tension nut too much the shoe could phall out.
Have you already gotten the new clutch, throttle/idle cables, and a new brake line? You will need those.
Old May 28, 2006 | 04:43 PM
SDMF's Avatar
SDMF
I still need to get the clutch, throttle cables and brake line. Where did you get your's from?? Harley? After market? What sizes over stock? Also, was the changing the clutch cable a pain in the a$$ or not? Not sure how much I can do on my own.
[IMG]local://upfiles/9114/010B12CC49E740608124ECC609F8CFE3.jpg[/IMG]
Old May 29, 2006 | 01:54 PM
16over's Avatar
16over
I ordered mine from Barnett. I went with 6" OS. Just about right for the throttle/idle cables, the clutch cable looks a little long, but it works. It wasn't too bad to change.
Old May 29, 2006 | 10:35 PM
JonHanna's Avatar
JonHanna
16over, for the same bars only 2" taller, would the +6" OS work for the throttle and idle cables? If the clutch is alittle long I take it will be fine with the 16"s?
your black prostreets and black gimps adds a great touch to yours[sm=smiley20.gif]
alika808
Mar 4, 2013 01:26 PM
Houston_t
May 16, 2012 09:47 PM
Ragnar Danneskjöld
Jun 22, 2011 11:14 PM
J-RoX
Jan 21, 2010 03:35 PM
labfreak
Nov 5, 2007 07:08 PM
