Stripped my fork stem nut today help
Old Aug 17, 2009 | 01:28 AM
reclaimer53's Avatar
reclaimer53
Default Stripped my fork stem nut today help
So as it goes now on my 08 FXDF about every 200 miles
I get the dreaded front end clunk.
I would go through proper adjustment checks and re-torque stem nut. I have the correct washer so not sure why it keeps needing to be re-adjusted and torqued. So the clunk comes up and I get pissed so I re torque again.
This weekend rolls around and again clunk. So I go through procedure and loosen stem nut but this time it won't budge and it seems the stem nut is stripped
Any suggestions on how to get it off? I've been both ways with it and it won't move. I'm so pissed at myself and the stupid clunking problem.
Old Aug 17, 2009 | 01:34 AM
cmiller1014's Avatar
cmiller1014
Warranty?
Old Aug 17, 2009 | 02:28 AM
sandsucker's Avatar
sandsucker
Heat will break down locktight but it might screw up the bearing.
Old Aug 17, 2009 | 02:34 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Heat may be your only choice at this point. I'd want my local HD shop to "fix it", and be parked outside their door when it returned in a week or a month so they could fix it again.
Old Aug 17, 2009 | 09:38 PM
reclaimer53
I'm going to see what the dealer can do as I have another
warranty issue with the rear brake dragging
Old Aug 17, 2009 | 10:03 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
The stem nut should not need tightening that often. Take it in.
Old Sep 4, 2009 | 09:14 PM
NoLongerAmember's Avatar
NoLongerAmember
So what did the dealer say about the clunk, etc? Please let us know what was the cause and fix?
Thanks,
CB
Old Sep 8, 2009 | 09:52 PM
reclaimer53
Default Update
Here is the update to my front end problem.
I took it to the dealer. They looked at it. No questions asked they covered it under the warranty.
Here is a copy of the work done.
Old Sep 9, 2009 | 12:14 AM
benwiggin2's Avatar
benwiggin2
F- Yeah! Good on ya for that one! I know you were sweating that one, eh?
Old Sep 9, 2009 | 12:44 AM
sycle1's Avatar
sycle1
Its not the stem nut that gets loose, its the bearing adjuster nut that gets loose, or is loose, it holds the bearing in underneath the top triple tree and it controls the amount of free play on the bearings, thats where the clunk comes from.
Tightening the stem nut just tightens the stem nut and has no effect on the clunk issue.
vessel
Dec 7, 2018 11:25 AM
gleam
Sep 15, 2018 04:58 PM
ironmike666
Apr 3, 2016 07:22 AM
Alain
Aug 19, 2013 05:53 AM
SportyPig
Sep 4, 2007 01:53 PM
